Two record numbers are shown on every Avey Drill when it leaves the factory.
Machine Serial Numbers shipped before 1928 were stamped on the countershaft loose pulley cap on Belted Avey Drills. After 1928, this machine serial number was stamped on a brass name plate attached to each machine.
Base numbers will be found stamped into the top of the lower column dovetail, which carries the table.
| Serial No. | Base Number | Type | Machine Description | Date |
| R9031 | 8215 | Drilling Machines | All Drills | Dec 1920 |
| R9233 | 8350 | Drilling Machines | All Drills | Dec 1921 |
| R9675 | 8651 | Drilling Machines | All Drills | Dec 1922 |
| R10347 | 9131 | Drilling Machines | All Drills | Dec 1923 |
| R10880 | 9681 | Drilling Machines | All Drills | Dec 1924 |
| R11642 | 10443 | Drilling Machines | All Drills | Dec 1925 |
| R11642 | 11259 | Drilling Machines | All Drills | Dec 1926 |
| R13374 | 12075 | Drilling Machines | All Drills | Dec 1927 |
| 14279 | 12815 | Drilling Machines | All Drills | Dec 1928 |
| 15405 | 13700 | Drilling Machines | All Drills | Dec 1929 |
| 15869 | 14120 | Drilling Machines | All Drills | Dec 1930 |
| 15985 | 14191 | Drilling Machines | All Drills | Dec 1931 |
| 16007 | 14225 | Drilling Machines | All Drills | Dec 1932 |
| 16034 | 14240 | Drilling Machines | All Drills | Dec 1933 |
| 161671 | 14322 | Drilling Machines | All Drills | Dec 1934 |
| 16428 | 14544 | Drilling Machines | All Drills | Dec 1935 |
| 16797 | 14896 | Drilling Machines | All Drills | Dec 1936 |
| 17349 | 15342 | Drilling Machines | All Drills | Dec 1937 |
| 175471 | 15539 | Drilling Machines | All Drills | Dec 1938 |
| 17783 | 15765 | Drilling Machines | All Drills | Dec 1939 |
| 18716 | 16384 | Drilling Machines | All Drills | Dec 1940 |
| 19944 | 17519 | Drilling Machines | All Drills | Dec 1941 |
| 21610 | 18919 | Drilling Machines | All Drills | Dec 1942 |
| 22830 | 20124 | Drilling Machines | All Drills | Dec 1943 |
| 234071 | 20644 | Drilling Machines | All Drills | Dec 1944 |
| 23983 | 21141 | Drilling Machines | All Drills | Dec 1945 |
| 24461 | 21538 | Drilling Machines | All Drills | Dec 1946 |
| 24730 | 21736 | Drilling Machines | All Drills | Dec 1947 |
| 24999 | 21961 | Drilling Machines | All Drills | Dec 1948 |
| 25197 | 22127 | Drilling Machines | All Drills | Dec 1949 |
| 25486 | 22375 | Drilling Machines | All Drills | Dec 1950 |
| 26123 | 22934 | Drilling Machines | All Drills | Dec 1951 |
| 26847 | 23601 | Drilling Machines | All Drills | Dec 1952 |
| 30714 | 30714 | Drilling Machines | All Drills | Dec 1953 |
| 31367 | 31367 | Drilling Machines | All Drills | Dec 1954 |
| 31832 | 31832 | Drilling Machines | All Drills | Dec 1955 |
| 32268 | 32268 | Drilling Machines | All Drills | Dec 1956 |
| 32553 | 32553 | Drilling Machines | All Drills | Dec 1957 |
- Serial Number Reference Book for Metalworking Machinery, by the Industrial Publishing Corp., 1959
