Page Revision: 2011/02/15 06:26
Here is an interesting video showing how bearings are made. It appears to be an NTN factory in Canada.
High Speed Bearings
Bearing Lifespan
  • bearing type
  • bearing size
  • operating speed
  • operating temperature
  • vibration levels
  • level of contamination
Grease Life
Cleaning Old Bearings for Regreasing
Drain the solvent and wash the bearing(s) in a second or third container of clean solvent until the bearings are completely clean. When the bearings are clean, they should immediately be protected against corrosion, and the solvent should be removed as it will break down any new grease packed in the bearing.
The clean bearings can be dried by using compressed air, but be *very* careful to hold both rings tight. Blow air into the bearing while holding both rings static. If the bearing is allowed to spin during drying, then the bearing can easily reach extreme speeds and with no oil in the bearing, the races will be damaged very quickly. Also make sure clean, dry air is used.
Another method is to shake most of the solvent from the bearings and then spin it by hand in light oil. The oil will remove the solvent. Wipe off the excess oil from the bearing surfaces, but make sure a thin coat stays for corrosion protection.
Do not give in to the temptation to use way oil or motor oil in bearings. Way oil is intended for for lathe ways and other sliding machine parts especially on metal working machines. As such it has different properties that make it unsuitable for use in bearings sticky, evaporates slowly, not easily washed away by cutting oil, resists drying, low resistance to heat. etc. Motor oil contains detergents to clear and engine of the products of combustion. Not necessary or desirable in an OWWM.
Felt Bearing Seals
Bearing Quality
ABEC 1NormalP0
ABEC 3Class 6P6
ABEC 5Class 5P5
ABEC 7Class 4P4
ABEC 9Class 2P2
ABEC 10.0150.00059
ABEC 30.0100.00039
ABEC 50.0080.00031
ABEC 70.0040.00016
Bearing Clearance Classes
Bearing Shelf Life
Bearing Fit on A Shaft
Heat Mounting
Nilos Ring
Nilos Ring
Purchasing Bearings
Where is it Made??
Where is it Made??
Bearing Nomenclature
Accurate Bearing's interchange guide, courtesy owwm.com (PDF)
New Departure Bearing Cross-Reference c.1961
http://wiki.owwm.com/GetFile.aspx?File=Ball_Brg_Cross_Ref%5cND%20Brg%20Guide.pdf
Electric Motor Bearing Reference c.1963
http://wiki.owwm.com/GetFile.aspx?File=Ball_Brg_Cross_Ref%5cMotor%20Ball%20Brg%201963.pdf
