Page Revision: 2011/02/15 06:26
Here is an interesting video showing how bearings are made. It appears to be an NTN factory in Canada.
Shielded/non-contact bearings have a metal plate covering the balls, cage, and races. Sealed/contact bearings have a (usually black) neoprene cover instead. Open bearings, as the name suggests, have no shields or seals and are open on the sides.
The big difference between a shield and a seal is the seal is a contact seal. The seals have a lip running on the inner ring of the bearing. The shield is a gap seal. It does not touch the inner ring. Sealed bearings have much more friction compared to shielded bearings, and thus are generally rated for lower speeds than shielded bearings. If you hold a shielded and sealed bearing in your hand and spin each, then you will clearly feel the difference in friction. A shielded bearing will almost spin free and a sealed bearing will not spin free.
A shielded bearing will run cooler at higher speeds, but it does not have the same dirt exclusion abilities of a sealed bearing. This creates the possibility of fine dust working into shielded bearings through the shields.
Open bearings are nice because you can always clean/repack with grease 10 or 20 years from now (assuming you and your machine are still alive and well), but are not suitable for locations where dirt/debris can get into the bearing. If the bearings are lubricated by an oil system, then open bearings must be used.
Ceramic bearings have the normal steel balls replaced by white ceramic balls. The ceramic balls are made of solid silicon nitride. Ceramic silicon nitride balls are called ceramic but have nothing in common with household dish ceramics. They are called ceramic because it's easier calling them ceramic then silicon nitride. The ceramic silicon nitride ball is by far, smoother, harder, lighter and stronger than one made off steel. Bearing Kinetics is one supplier.
Sealed for life bearings work better in applications where you don’t have the fine dust you see in woodworking. This super fine dust functions like silica gel for bearing volatiles and can greatly shorten the life of your bearings by drying up the lube. For example, Oliver 299 type one planers use grease zerks for lubricating the bearings. In this case, it’s unreasonable to have oilers in all those bearings with the bed rollers, section infeed rollers, outfeed rollers etc. On type two machines, Oliver switched to sealed for life bearings. They are expensive and require much more rebuild effort than a zerk greaser or a full bath oiler. Jointers are also a natural for this type of bearing and it works great.
High Speed Bearings
To make a bearing functioning properly when running fast you need to keep it lubed and to keep it cool. Too low of a lube viscosity means the lube gets thrown out, and your balls aren't slick anymore. Raise the viscosity of the lube and it stays where it is supposed to be, but now you generate more heat .
An interesting question is: when is a speed considered to be "high speed" for a certain bearing size, and thus when do you need to consider special cage designs? For that there is a speed factor called ndm that can be calculated.
- Pressed steel cage: up to ndm = 600,000
- Machined brass cage: up to ndm = 1,200,000
- Polymer cages: up to 1,400,000 depending on cage design
Bearing Lifespan
- bearing type
- bearing size
- operating speed
- operating temperature
- vibration levels
- level of contamination
- horizontal / vertical mounting
Grease Life
Regarding grease type, the originally specified (good luck finding that info…!) grease in the bearing will be good up to the speed rating of the bearing. Standard factory filled greases are something like Exxon Polyrex EM or a type of Shell Alvania. If you get close to or above the speed rating of the bearing, then a special high speed grease is needed. Synthetic greases are great, because they can handle high temperatures much better and have longer grease lives.
Other things being equal, open bearings in oil can run at higher design speeds (rpms). The same bearing in grease has a lower RPM rating. Which grease you use can make a difference. The open bearing has nothing to stop the flow of lubricant in and out of the bearing, thus no heat producing friction from a seal.
Cleaning Old Bearings for Regreasing
Drain the solvent and wash the bearing(s) in a second or third container of clean solvent until the bearings are completely clean. When the bearings are clean, they should immediately be protected against corrosion, and the solvent should be removed as it will break down any new grease packed in the bearing.
The clean bearings can be dried by using compressed air, but be *very* careful to hold both rings tight. Blow air into the bearing while holding both rings static. If the bearing is allowed to spin during drying, then the bearing can easily reach extreme speeds and with no oil in the bearing, the races will be damaged very quickly. Also make sure clean, dry air is used.
Another method is to shake most of the solvent from the bearings and then spin it by hand in light oil. The oil will remove the solvent. Wipe off the excess oil from the bearing surfaces, but make sure a thin coat stays for corrosion protection.
Do not give in to the temptation to use way oil or motor oil in bearings. Way oil is intended for for lathe ways and other sliding machine parts
especially on metal working machines. As such it has different properties that make it unsuitable for use in bearings sticky, evaporates slowly, not easily washed away by cutting oil, resists drying, low resistance to heat. etc. Motor oil contains detergents to clear and engine of the products of combustion. Not necessary or desirable in an OWWM.
Felt Bearing Seals
Bearing Quality
| ABEC SYSTEM | ISO SYSTEM | DIN SYSTEM |
| ABEC 1 | Normal | P0 |
| ABEC 3 | Class 6 | P6 |
| ABEC 5 | Class 5 | P5 |
| ABEC 7 | Class 4 | P4 |
| ABEC 9 | Class 2 | P2 |
- How close the bore is to 8mm in microns
- How close the outer diameter is to 22 in microns
- How close the width is to 7mm in microns
- The rotating accuracy in microns
| Grade | Max Radial runout (mm) | Max Radial runout (inch) |
| ABEC 1 | 0.015 | 0.00059 |
| ABEC 3 | 0.010 | 0.00039 |
| ABEC 5 | 0.008 | 0.00031 |
| ABEC 7 | 0.004 | 0.00016 |
Bearing Clearance Classes
NTN Bearing Corp. article on internal clearance (PDF)NTN Bearing Corp. article on tolerances (PDF)Bearing Shelf Life
All bearings should be stored in a protected area that is relative vibration and dirt free and not subject to extreme temperatures or excessive humidity.
Some rules of thumbs can also be used. Shielded bearing shelf life is in the 5 year range. Service life is in the 8 year range. Sealed bearing shelf life is in the 10 year range. Service life is 12 to 14 year range.
Bearing Fit on A Shaft
Heat Mounting
Heat mounting is a very good way to mount bearings, particularly shielded bearings, if you don't have a press. This process will not work for bearings sealed with rubber or rubber-like materials. Shield bearing have metal covers that enclose the sides of the bearing, and thus have nothing to melt. Heat mounting reduces the risk of bearing or shaft damage during installation, because the bearing can be slid easily onto the shaft. As the bearing cools, it contracts and tightly grips the shaft. It’s important to heat the bearing uniformly, and to regulate heat accurately, since excess heat destroys a bearing’s metallurgical properties, softening the bearing, and can also damage the grease.
Never heat a bearing using an open flame, such as a blowtorch. Appropriate electric-heat bearing mounting devices include induction heaters, ovens and hot plates. Of these, induction heaters and ovens are the most convenient, and heaters the fastest, devices to use. Modern bearing induction heaters are a real pleasure to use, because they have a magnetic temperature probe that mounts on the bearing inner ring. You set the temperature and when the bearing reaches the required temperature, it shuts down to prevent over-heating the bearing, and automatically starts again when the bearing cooled down 20 degrees. Toaster ovens, with their radiant elements, may heat the rubber seals or grease faster than the shiny metal parts, but are popular for this application due to their ubiquity and ability to control the temperature. (Turn the fan on in the kitchen as you will get a “slight” warm grease smell coming out of the oven!)
Simply setting the bearing on an exposed incandescent light bulb also works well. Due to the curvature of the bulb, most of the heat is directed into the inner race, although it can be difficult to regulate the temperature.
The 88506 and 6206 are not interchangeable because the 88506 has wider extended inner rings. But, using 6206's gives many more options with seal, clearance and grease options than using 88506’s does. There are several possible methods for replacing 88506’s with 6206’s.
One method is to making on a lathe spacer bushings for above and below the bearing. Thus a “sandwich” of spacer|6206|spacer replaces the 88506.
Nilos Ring
Purchasing Bearings
Where is it Made??
Get at least a Nachi (Japanese) brand or better and you won't have to worry about what's going to happen in a couple of years. Nachi is a medium quality brand. Fafner, NSK, SKF, are all top of the line bearings.
Many folks feel that when they are going to all the trouble of tearing a machine down to rebuild or repair, that a few extra dollars spent on better quality bearings is well worth it.
On the other hand, so what if the bearings get a “short” life until failure, maybe they fail at 10,000 hours. How many hours are going to be logged on your machine each week in a one man shop? Even ten hours a week gives a lifespan of 1000 weeks, or nearly 20 years of service.
Bearing Nomenclature
AHR International's extensive library of bearing manufacturers part number systems.Accurate Bearing's interchange guide, courtesy owwm.com (PDF) New Departure Hyatt ball bearing part number system"Gizmologist" notes on ball bearing nomenclatureNew Departure Bearing Cross-Reference c.1961
http://wiki.owwm.com/GetFile.aspx?File=Ball_Brg_Cross_Ref%5cND%20Brg%20Guide.pdfElectric Motor Bearing Reference c.1963
http://wiki.owwm.com/GetFile.aspx?File=Ball_Brg_Cross_Ref%5cMotor%20Ball%20Brg%201963.pdf
