Page Revision: 2008/04/12 18:45
High Speed Bearings
Bearing Lifespan
  • bearing type
  • bearing size
  • operating speed
  • operating temperature
  • vibration levels
  • level of contamination
Grease Life
Felt Bearing Seals
Bearing Quality
ABEC 1NormalP0
ABEC 3Class 6P6
ABEC 5Class 5P5
ABEC 7Class 4P4
ABEC 9Class 2P2
ABEC 10.0150.00059
ABEC 30.0100.00039
ABEC 50.0080.00031
ABEC 70.0040.00016
Bearing Clearance Classes
Bearing Shelf Life
Bearing Fit on A Shaft
Heat Mounting
Nilos Ring
Nilos Ring
Purchasing Bearings
Where is it Made??
Where is it Made??
Bearing Nomenclature
Accurate Bearing's interchange guide, courtesy owwm.com (PDF)
