Page Revision: 2008/11/30 19:19
by Bill NanceIntroduction
This page shows the process and parts involved in assembling a compound slide rest for a Delta 12" wood lathe. The part numbers referenced in this page are taken from manual #PM-1533, dated 1/15/1948. Reprints can be found at:
Delta Compound Slide Rest Manual #PM-1533.
While one might expect the reassembly to start with the sub-base, that is actually the final step. Access is needed inside the base, so instead, we start with the base and lower feed screw.
Base, DDL-226-R
The first step is to install the lower feed screw assembly within the base.
After assembling the base and lower feed screw, the next step is to install the upper feed screw assembly within the swivel saddle.
Upper Feed Screw installed in Swivel Saddle, DDL-228
Once the two feed screw mechanisms are assembled, the two assemblies are attached using the lower slide. Square-head T-bolts are installed within slots in the lower slide, and then a steel pin, DDL-248, is installed through the lower slide into the indexed lower cylinder on the saddle. The lower slide gib, DDL-251, needs to be installed and adjusted along the dovetailed way.
Lower Slide, DDL-227
Bottom view of base, lower slide and swivel saddle assembled
Top view of base, lower slide and swivel saddle assembled, Lower Slide Gib not yet installed
Once the three main castings are assembled, the top slide is attached. The Upper Slide Gib, DDL-252, needs to be installed and adjusted along the dovetailed way.
Top slide to be installed w/ gib on dovetailed way
The last assembly step is to install the Sub Base on the bottom of the entire assembly.
Sub Base ready for mounting, CBL-405
Sub Base installed using Special Hex Socket Cap Screws, CBL-430
Finally, the cross slide is mounted on lathe bed using two standard lathe clamp plates, CBL-406.
Cross Slide 46-965 installed on lathe
