Page History: Crescent Heavy 8-inch Jointer
Page Revision: 2008/09/25 16:38
1903 Catalog
| Length of tables | Front. 83; rear 30 inches. |
| Height of table from floor. | 33 inches. |
| Floor space required, over all | 21x64 inches. |
| Cubic measure, boxed for export | 24 feet. |
| Gross weight, boxed for export | 1,000 pounds. |
| Net weight | 800 pounds. |
| List price of machine | $130 |
| Telegraphic code word | Ennoergie. |
