Page Revision: 2008/09/25 15:10
1903 Crescent Catalog
| Floor space required, aver all | 31x80 | 37x80 | 43x80 |
| Cubic Measure, boxed for export | 40ft. | 48ft. | 56ft. |
| Gross Weight, boxed for export | 1,500 | 1,775 | 2,000 |
| Net Weight | 1,250 | 1,450 | 1,650 |
| List Price for Machine | $150 | $170 | $190 |
| Telegraph Code Word | Ennovelar. | Ennoyage. | Ennuvear. |
