Page Revision: 2008/10/03 10:52
Back to Crescent Jointers main pageCrescent Heavy Jointers - 12-inch or Wider Models
- Crescent 12” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945, 1946)
- Crescent 16” Jointer (Introduced in 1912,1916,1918,1921,1923,1925,1928,1930,1939, 1945, 1946)
- Crescent 18” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
- Crescent 20” Jointer (Introduced in 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
- Crescent 24” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
1903 Crescent Catalog
| Floor space required, aver all | 31x80 | 37x80 | 43x80 |
| Cubic Measure, boxed for export | 40ft. | 48ft. | 56ft. |
| Gross Weight, boxed for export | 1,500 | 1,775 | 2,000 |
| Net Weight | 1,250 | 1,450 | 1,650 |
| List Price for Machine | $150 | $170 | $190 |
| Telegraph Code Word | Ennovelar. | Ennoyage. | Ennuvear. |
1910 Catalog
The Crescent Jointers
8, 12, 18 and 24-InchA JOINTER is sometimes also called a hand-planer, or a buzz-planer. The machine is used for straightening lumber. It will plane one surface straight and out-of-wind; by use of the fence it will also bring one surface, on dimension stock, square with another, or on accurate bevel with another. It is not intended for surfacing boards to uniform thickness. For such use a regular planer or surfacer must be used. By use of special cutters a jointer is often used for beading, grooving, making light molding and other similar work.
| | 12 in. | 18 in. | 24 in. |
| Length of Knives | 12 in. | 18 in. | 24 in. |
| Length of front table | 42 in. | 42 in. | 42 in. |
| Length of rear table | 36 in. | 36 in. | 36 in. |
| Width of tables | 17 in. | 23 in. | 29 in. |
| Height of table from floor | 33 ½ in. | 33 ½ in. | 33 ½ in. |
| Size of flanged pulley on head | 4 x 4 ½ in. | 4 x 4 ½ in. | 4 x 4 ½ in. |
| Widest belt that should be used | 4 in. | 4 in. | 4 in. |
| Size of bearing on pulley end | 1 ½ x 7 in. | 1 ½ x 7 in. | 1 ½ x 7 in. |
| Size of bearing on operator end | 1 ½ x 5 in. | 1 ½ x 5 in. | 1 ½ x 5 in. |
| Size of tight and loose pulleys | 10 x 5 in. | 10 x 5 in. | 10 x 5 in. |
| Speed of countershaft per minute | 800 rev. | 800 rev. | 800 rev. |
| Giving head a speed of | 4,000 rev. | 4,000 rev. | 4,000 rev. |
| Floor space, exclusive of countershaft | 31 x 80 in. | 37 x 80 in. | 43 x 80 in. |
| Cubic measure, boxed for export | 33 ft. | 49 ft | 58 ft. |
| Gross weight, boxed for export | 1,400 lbs. | 1,650 lbs. | 1,900 lbs. |
| Domestic shipping weight | 1,275 lbs. | 1,500 lbs. | 1,700 lbs. |
| Square Head, regular solid lips | No. 121 | No. 181 | No. 241 |
| Telegraphic code word | Elden | Enlin | Enome |
| Square Head, steel 1ips | No. 122 | No. 182 | No. 242 |
| Telegraphic code word | Erato | Gande | Gamon |
| Safety Head, regular solid lips | No. 123 | No. 183 | No. 243 |
| Telegraphic code word | Gowan | Hecti | Henco |
| Safety Head, steel lips | No. 125 | No. 185 | No. 245 |
| Telegraphic code word | Heran | Hamar | Hymen |
1912 Catalog
According to the 1912 catalog, that issue marked the introduction of two new sizes of Crescent Jointers. These would be the 16 and 20-inch models. With this introduction, Crescent now offered jointers in the 8, 12, 16, 18, 20 and 24-inch sizes.
Engravings of the jointers in the catalog also show one other new feature – a vertical scale being added to the fence. The scale was designed so that it read the thickness of a piece of wood placed against it after the cut would be made. Using this feature, one could adjust the depth of cut to match the final dimension of after the cut. The catalog does not specify when this feature was added but one could speculate that it was a feature added in 1911 as it was not mentioned in the 1910 catalog but detailed as a feature in the 1912 issue. New catalogs were issued by Crescent yearly and any new features for that year were stated at the front of the catalog.
Vertical Scale
One other change noticed in the engravings between 1910 and 1912 is on the front hand wheels on the jointers. In the 1910 catalog, all jointers in the catalog had two hand wheels on the front of the machine which were used to tighten the in-feed and out-feed tables to allow them to move laterally in and out from the cutter-head. In the 1912 catalog, these hand wheels were replaced with levers mounted on the back of the jointer on the 12-inch and larger models. The front hand wheels remained on the 8-inch jointer.
Hand Wheels
Some differences were also noted in the dimensions tables between the 1910 and 1912 catalogs. The length of the tables on the 8” jointer were changed from 33 in. and 30 in. for the front and rear tables respectively to 33 ½-inches for each table. Table lengths on the 12-inch and larger jointers were also changed from 42 in and 36 in for the front and rear tables respectively to 40-inches for each table. The change in table lengths resulted in the 12-inch and larger jointers being about 2-inches longer than earlier models. The 1912 catalog also states that the width of the tables on the 12-inch and larger jointers were also made a slight bit narrower than what was described in the 1910 catalog. The only other differences noted in the dimensions table was that the weight of the 12-inch and larger jointers had increased slightly over what was reported in the 1910 catalog, assumingly due to the longer tables.
