Page Revision: 2008/10/03 10:15
- Crescent 12” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945, 1946)
- Crescent 16” Jointer (Introduced in 1912,1916,1918,1921,1923,1925,1928,1930,1939, 1945, 1946)
- Crescent 18” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
- Crescent 20” Jointer (Introduced in 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
- Crescent 24” Jointer (1903, 1904, 1910, 1912, 1916, 1918, 1921, 1923, 1925, 1928, 1930, 1939, 1945)
1903 Crescent Catalog
| Floor space required, aver all | 31x80 | 37x80 | 43x80 |
| Cubic Measure, boxed for export | 40ft. | 48ft. | 56ft. |
| Gross Weight, boxed for export | 1,500 | 1,775 | 2,000 |
| Net Weight | 1,250 | 1,450 | 1,650 |
| List Price for Machine | $150 | $170 | $190 |
| Telegraph Code Word | Ennovelar. | Ennoyage. | Ennuvear. |
1910 Catalog
The Crescent Jointers
8, 12, 18 and 24-InchA JOINTER is sometimes also called a hand-planer, or a buzz-planer. The machine is used for straightening lumber. It will plane one surface straight and out-of-wind; by use of the fence it will also bring one surface, on dimension stock, square with another, or on accurate bevel with another. It is not intended for surfacing boards to uniform thickness. For such use a regular planer or surfacer must be used. By use of special cutters a jointer is often used for beading, grooving, making light molding and other similar work.
| | 12 in. | 18 in. | 24 in. |
| Length of Knives | 12 in. | 18 in. | 24 in. |
| Length of front table | 42 in. | 42 in. | 42 in. |
| Length of rear table | 36 in. | 36 in. | 36 in. |
| Width of tables | 17 in. | 23 in. | 29 in. |
| Height of table from floor | 33 ½ in. | 33 ½ in. | 33 ½ in. |
| Size of flanged pulley on head | 4 x 4 ½ in. | 4 x 4 ½ in. | 4 x 4 ½ in. |
| Widest belt that should be used | 4 in. | 4 in. | 4 in. |
| Size of bearing on pulley end | 1 ½ x 7 in. | 1 ½ x 7 in. | 1 ½ x 7 in. |
| Size of bearing on operator end | 1 ½ x 5 in. | 1 ½ x 5 in. | 1 ½ x 5 in. |
| Size of tight and loose pulleys | 10 x 5 in. | 10 x 5 in. | 10 x 5 in. |
| Speed of countershaft per minute | 800 rev. | 800 rev. | 800 rev. |
| Giving head a speed of | 4,000 rev. | 4,000 rev. | 4,000 rev. |
| Floor space, exclusive of countershaft | 31 x 80 in. | 37 x 80 in. | 43 x 80 in. |
| Cubic measure, boxed for export | 33 ft. | 49 ft | 58 ft. |
| Gross weight, boxed for export | 1,400 lbs. | 1,650 lbs. | 1,900 lbs. |
| Domestic shipping weight | 1,275 lbs. | 1,500 lbs. | 1,700 lbs. |
| Square Head, regular solid lips | No. 121 | No. 181 | No. 241 |
| Telegraphic code word | Elden | Enlin | Enome |
| Square Head, steel 1ips | No. 122 | No. 182 | No. 242 |
| Telegraphic code word | Erato | Gande | Gamon |
| Safety Head, regular solid lips | No. 123 | No. 183 | No. 243 |
| Telegraphic code word | Gowan | Hecti | Henco |
| Safety Head, steel lips | No. 125 | No. 185 | No. 245 |
| Telegraphic code word | Heran | Hamar | Hymen |
