Page History: DeWalt MBF & MBC Motor Bearing Replacement
Page Revision: 2008/03/29 14:52
A Japanese JAF 88500 was used to replace the Fafnir 200KLL2 on the cord side and a Japanese IKS 88504 to replace the New Departure C 88504 on the arbor side. These bearings were ordered from http://accuratebearing.com/ Accurate Bearing and are fairly standard.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF08.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF12.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF13.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF18.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF20.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF23.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF26.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF17.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF28.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF29.jpg http://www.wiki.owwm.com/attachments/images/DeWaltMBF31.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF35.jpg
From owwm.org thread: http://owwm.org/viewtopic.php?t=30990
