Page History: DeWalt MBF & MBC Motor Bearing Replacement
Page Revision: 2008/03/29 14:55
A Japanese JAF 88500 was used to replace the Fafnir 200KLL2 on the cord side and a Japanese IKS 88504 to replace the New Departure C 88504 on the arbor side. These bearings were ordered from http://accuratebearing.com/ Accurate Bearing and are fairly standard.
Title
Title
Title
Title
Title
Title
Title
Title
Title
Title Title
Title
From owwm.org thread: http://owwm.org/viewtopic.php?t=30990
