Page History: DeWalt MBF & MBC Motor Bearing Replacement
Page Revision: 2008/03/29 18:07
A Japanese JAF 88500 was used to replace the Fafnir 200KLL2 on the cord side and a Japanese IKS 88504 to replace the New Departure C 88504 on the arbor side. These bearings were ordered from Accurate Bearing and are fairly standard.
DWMBF
DWMBF
DWMBF
DWMBF
DWMBF
DWMBF
DWMBF
DWMBF
DWMBF
DWMBF DWMBF
DWMBF
From owwm.org thread: http://owwm.org/viewtopic.php?t=30990
