Page Revision: 2025/06/30 13:08
The entry looks like this:
Delta Mfg. Co.
Actual dimensions of various decals used on the 890 band saw and open stand
Submitted by Thomas Scheuzger (Right click and select "save target as" to download High-res version)
Delta / Marathon Motor Tag
Double Duty Motor Badge-2.25 inches x 4inches
- Submitted by Thomas Scheuzger (Right click and select, in IE "Save Target As", in Firefox "Save Link As")
Delta Triple Duty Grinder Pedestal Badge
submitted by Dane Johnson (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
Delta / 14
Delta / 14" Bandsaw
Cat 62110A Motor Badge-Submitted by Tom Scheuzger
Submitted by NeilB.
Submitted by NeilB.
Delta Triple Duty Grinder 1
Delta Triple Duty Grinder 2
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Delta Quality Tools Label
Delta / 654 Jointer Decal
Delta 1948 Scroll Saw
Delta Important
Delta Important
1939-40 Patent Decal-Submitted by Thomas Scheuzger
CATALOG NO. 1356-Submitted by Larry Buskirk
Delta Bullet Motor Tag, Single Phase
Submitted by S. Vick, created by Ja'Nette (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
Delta Bullet Motor Tag, Three Phase
