Page Revision: 2017/10/13 02:05
To use the pattern, print out, align and assemble with tape if printing on multiple sheets of paper (alternatively, you can have a print shop print it on one piece of paper). Lay the pattern onto a piece of sheet metal (I used 26 gauge) and transfer the relevant points (A,B,C... 1,2,3... & fastener drill positions on seam) using a punch. Remove the paper and draw connecting lines to match the pattern on the metal using a straight edge.Laying out pattern on sheet metal Cut out the pattern. Bend each dashed line approximately 13 degrees with a metal bending brake (I made my own with angle iron, a two-by-four, and some old door hinges). Drill the holes for fasteners along the seam(s).
Download printable PDF of pattern: PDF of Delta Unisaw Dust Collection Funnel Pattern
