Page Revision: 2009/04/24 21:49
IN PROGRESSTop Drum Cover
From Bob Vaughan:
Before filling, fiberglass can be applied to the inside as reenforcement. A fiberglass repair kit should be available from your local auto parts store.
Fitting Newer Covers
Newer top covers won't usually fit earlier sanders without some modifications being made{Reference:http://owwm.org/viewtopic.php?t=25277|6X48 complete, have an issue}:
Note also that new/old top covers won't work properly with old/new side covers. The shape of the bump-out where they meet is a different shape. The newer ones have a straighter side to the bump-out.{Reference:http://owwm.org/viewtopic.php?t=50230|Pics! Delta 6" Belt 12"DiskSander #31-730 for $100}
Side Cover
From Bob Vaughan:
Lower Drum Cover
The lower drum covers also differ between newer and older sanders:
See the link below for Jamie Norwood's solution to the problem.
See Also
