Page Revision: 2009/04/24 01:09
WARNING: Read this whole section before proceeding with removal of the upper shaft. It is not uncommon to break the idler arm casting as seen below{Reference:http://owwm.org/viewtopic.php?t=15145|Removing spindle from Delta 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=15318| Removing spindle from Delta 6x48 sander.. continued}.
Shaft Fabrication
