Page Revision: 2009/04/24 22:22
{Reference:http://owwm.org/viewtopic.php?t=15145|Removing spindle from Delta 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=15318| Removing spindle from Delta 6x48 sander.. continued}{Reference:http://owwm.org/viewtopic.php?t=41911|Rockwell 6x48 Belt Sander Bearings}{Reference:http://owwm.org/viewtopic.php?t=50397|Delta sander 31-710 bearing removal}
A press is recommended, if not fully required. Pounding on the shaft is unlikely to move it. The clamshell drum halves are a slip fit and should just slide off but old ones rarely, if ever, do that. The steel shaft sometimes galvanic welds to the drums, requiring significant extra pressure to break the bond.{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
Comparisons to Powermatic 30
Shaft Fabrication
Shaft fabrication is easy with a metal lathe. Take 15mm ground rod (see links below for source) and thread the ends to fit the fine nuts you have. Newer shafts have different threads to older ones (see pictures above).{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=27705|Delta 6x48 upper (idler) shaft question?}{Reference:http://www.owwm.org/viewtopic.php?t=41918|Delta 6x48 31-730 sander repair details(16 pictures)}
