Page Revision: 2009/04/24 01:21
{Reference:http://owwm.org/viewtopic.php?t=15145|Removing spindle from Delta 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=15318| Removing spindle from Delta 6x48 sander.. continued}{Reference:http://owwm.org/viewtopic.php?t=41911|Rockwell 6x48 Belt Sander Bearings}
Comparisons to Powermatic 30
Shaft Fabrication
