Page Revision: 2009/04/23 20:48
Do not follow the below image yet, you may break the casting. More description to come.The clamshell drum halves are a slip fit. They should just slide off. That said, old ones rarely, if ever, do that. Once things are cleaned up it will slip back together. The steel shaft sometimes galvanic welds to the drums.{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
Shaft Fabrication
Shaft fabrication is easy with a metal lathe. Take 15mm ground rod (see links below for sources) and thread the ends to fit the fine nuts you have. Newer shafts have different threads to older ones (see pictures above).{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
