Page Revision: 2012/03/04 18:01
(from a post on OWWM.org by
by Keith Bohn 09/24/06)
http://www.owwm.org/viewtopic.php?t=20014
Delta No. 667 Cast Iron Stand¶
- NJ-273 Front Base Panel
- NJ-275 Right Hand Base Panel
- NJ-276 Left Hand Base Panel
- NJ-277 Motor Plate
- NJ-283 5/16-18 Knurled Nuts (4-req’d.)
- NJ-287 Pulley Guard
- NJ-288 Rear Base Panel
- Cat. No. 132 Switch Box With SP-2458 Switch (purchased separately)
- DP-741 Front Name Plate (Vertical DELTA Plate)
- LSR-35 Delta Switch Plate Cover (domestic machines)
- LSR-36 TAUCO Switch Plate Cover (export machines)
Delta No. 886 Cast Iron Stand¶
- LBS-225 Front Base Panel
- LBS-226 Rear Base Panel
- LBS-227 Left Hand Base Panel
- LBS-228 Right Hand Base Panel
- LBS-229 Motor Mounting Plate
- LBS-194 Cover Casting for Cat. No. 883 Cast Iron Hinged Belt Guard
- NJ-283 5/16-18 Knurled Nuts (8-req’d.)
No. 31-852 Abrasive Finishing Machine Stand:¶
No. 31-852 Cast Iron Stand
- BS-263 Sub-Base
- BS-264 Pulley Guard
No. 886 Stand for Tablesaw
- TCS-316A & TCS-317A (Cat. No. 1173) Belt Guard
No. 37-302 Cast Iron Stand¶
No. 37-302 Jointer Stand
- JA-1 Base Front Panel
- JA-2 Base Back Panel
- JA-3 Motor Cover
- JA-29 Motor Mounting Plate
- JA-32 Pulley Guard
- JA-49 Name Plate
No. 31-852 & No. 886 Comparison Photos
 No. 31-852 on left, No. 886 on right - image courtesy of Jeff Parker (JParker) |
 No. 31-852 on left, No. 886 on right - Image courtesy of Jeff Parker (JParker) |
