Page Revision: 2017/03/16 09:44
by Keith Bohn plus contributions and edits from the community
The easiest way to vintage a Delta machine is of course with the serial number. There are guidelines though. Delta began assigning serial numbers
in 1941. If your machine lacks a serial number plate or holes to mount one then it is from early 1941 or before.
We have divided the serial number plates used by Delta into three styles, as detailed below.
Style 1 plates were made of aluminum and measured 1/2" X 3" with rivet holes approximately 2 3/4" on center. This style was used beginning circa 1939-1940 to sometime in 1942 (probably early 1942), and then again from sometime in 1944 to late 1947.
Style 2 plates are from the World War II era, and are made from one of three materials: brass, steel or oilboard. Style 2A plates were made of brass plate and are from late 1941 or early '42. They are very rarely seen.
 Delta Brass Wartime Plate |
Another reported example of a brass plate had a red-painted background. It's possible that the plate shown above originally had a red background.
Style 2B plates were made of steel, appeared in 1942, and are quite rare.
 Delta Steel Serial Number Plate |
Style 2C plates were made of "oilboard" (dense coated cardboard) and measured 3/4" x 3" with rivet holes spaced the same as the first style plates. They were used between early 1942 to sometime in 1944. They are fairly common but are somewhat fragile and are often missing or in poor condition.
Style 3 plates were introduced in late 1947. They are made of aluminum and measure 1" x 4" with rivet holes approximately 3-3/4" on center.
Some machines, for whatever reason, may have had their serial number plates removed or torn off, making a positive vintage identification more difficult. You can however locate the rivet or screw holes in the machine and perhaps a ghost image of the plate, and use the distance between the holes to narrow down the machine's vintage: 2 3/4" means that the missing plate was Style 1 or 2, and 3 3/4" means a Style 3 plate. Where plates were located on individual machines would take a paper unto itself. I should also note, plate locations on the same machines weren't always located in the same spot. For instance, I've seen plates on the back of a Unisaw cabinet as well as the front. Keep in mind that machines made prior to 1941 did not have serial number plates at all.
Please read the rest of this article though before positively determining your machine's vintage. It's also come to light, from various discussions on the OWWM discussion forum, that Delta used some serial numbers during the same period that don't quite jive with what's known by me. For instance, some five digit serial numbers on 1x4 plates don't compute with my list or Delta's. If ever this mystery is solved this write up will be amended.
Delta's Serial Number List:
do not expect it to be the 'last word'. If you called them, Delta used to be able to give you the month the machine was manufactured. This is something you won't get from the list below, and now that Delta has disappeared from these shores, that detailed information has been lost.
The following is based on
The strange jump from 15-0000 to 16-0000 is in the original. If your serial number lies between these two values then all we can say is that your saw dates from 1941 or '42. The brass serial number tag, above, shows a 15-xxxx serial number.
| Year | From | - | To |
The Bellefountaine Years:
| Year | From | | To |
| 1962 | CU-4300 | - | CX-9999 |
Example: 83B01234
| A = October | G = April |
| B = November | H = May |
| C = December | I = June |
| D = January | J = July |
| E = February | K = August |
| F = March | L = September |
original document.
goes on it's hoped that all of these changes will be brought to light and put in written form. In the mean time feel free to email me with
Decals and Plates: ¶
Milwaukee/Pittsburgh:
Stands and Motors: ¶
Part Numbers:
Got A Receipt?:
