Page Revision: 2008/03/30 02:00
November 21, 2006
Early Band Saws in the OWWM Archives: A Research Paper in Eight Parts¶
Part 1. Patent dates and four footed cast iron, cast iron wheeled band saws¶
Welch & Chipman saw
Welch, Harrison & Co. saw
C.B. Rogers & Co saw
June 16, 1868 cast into them, and, therefore both saws were manufactured after that date. The four Pryibil related saws have several patent dates attached or cast onto them, as follows:
- First & Pryibil ('Woodshave' example) said to be 1876
- Pryibil (Barnhart example) 1866 & '73
May 26, 1874May 26, 1874. Therefore this saw could not have been manufactured prior to that time.
after June 16, 1868
after June 16, 1868
- First & Pryibil (Steere example)
after January, 1873
after January, 1873
after January, 1873
after August 12, 1873
after May 26, 1874
after 1876
Concord NH
Lebanon NH
Norwich CT
South Boston MA
South Boston MA
Concord NH
Lebanon NH
- First & Pryibil (2 examples)
New York NY
New York NY
Norwich CT
South Boston MA
South Boston MA
Part 2. Patent Dates and other early band saws that are non four footed, but are cast iron and do not have fully cast iron wheels¶
- Atlantic Works (5 examples)
- J.A. Fay & Co. (3 examples)
- Goodell & Waters (2 examples)
- L. Power & Co. (2 examples)
- Baxter D. Whitney (1 example)
- J.A. Fay & Co. (as Page & Co.) 1834 (as J.A. Fay & Co.) prior to 1850
- Baxter D. Whitney (circa 1837)
- L. Power & Co. (circa 1867)
- Goodell & Waters (as Goodell, Braun & Co.) prior to 1869 (as Goodell & Waters) circa 1873 or 1874
- Atlantic Works (as Richards, Kelley, & Co.) 1870
Part 3. Comparison of earliest i.e. not latest patent dates of early band saws¶
* J.A. Fay & Co.
Haire example Reissued Aug. 25. 1865, Pat June 16.1868, Sept. 1. Nov. 1. 1871, May 21. 1872, May 19. 1874.
* First & Pryibil
'Woodshave' example said to be 1876
prob '1866 * Pryibil
Poore example 'Pat Aug 28 1866 & Jan 73'
* Pryibil
Barnhart example 'Pat 1866 & 73'
* Welch, Harrison
June 16, 1868
* Welch & Chipman
June 16, 1868
* J.A. Fay & Co.
Buck example June 16, 1868, Sept 19, 1871, Nov. 14, 1871, May 21, 1872, May 19,1874
* First & Pryibil
Steere example Aug 28, 1868 & Jan 1873
* Atlantic Works
Potts example L.B & O June 7, 1870, Jun. 28, 1870, Apr. 25, 1871, May 9, 1871
* Atlantic Works
Gee example L.B. & O June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
* Atlantic Works
Hanson example June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
* J.A. Fay & Co. example?
May 19, 1874
only date recorded may be others? * Goodell & Waters
Fisher example said to be 1882
* Reissued Aug. 25. 1865
* Pat June16, 1868,
* Sept. 1 Nov. 1 1871,
* May 21, 1872,
* May 19, 1874.
Reissued Aug. 25. 1865 no J.A. Fay & Co patent this date
Pat June16, 1868, Improvement in guides for bandsaws
Sept. 1 Nov. 1 1871, no J.A. Fay & Co patent these dates
May 21, 1872, Improvement in pulleys for bandsaws
May 19, 1874. Improvement in band sawing machines
Part 4.
Jun. 16, 1868 J.A. Fay John Lemman
|Jun. 28, 1870 Atlantic Works William H. Thorne
1837 Baxter D. Whitney
1847 J.A. Fay
1867 L. Power
c. 1869 Goodell & Waters
c. 1869 Atlantic Works
