Page Revision: 2010/02/10 12:24
I recently bought an old Delta DP220 which had a broken switch. I am under the impression from what I’ve read here that some of these old Delta switches can be hard to come by. (Boy, I sure hope so, after the work I put in on this.) So I fixed it. I always enjoy sharing too, so I documented what I did. I hope you enjoy this.
This was the switch:
My solution is to simply grind the flat top of the bolts down to the level of the switch top and remove the bolts. We’ll fix the shortened bolts later. Note the lettering on the metal switch top PAT NO 1880259. Also note the similar lettering on the Bakelite bottom. On this switch this lettering reads the same direction. That is, when this switch is rotated on its axis, the lettering top and bottom is left to right. Look for, and note, your switch’s indications of direction so you can reassemble it correctly. This matters.
Remove the switch top:
A word about toggle pins. . .
PIN TYPE ONE:
PIN TYPE TWO:
MAKE A NEW TOGGLE:
I was fortunate to have both pieces of my broken toggle. However, the inside toggle piece is the critical piece, and, obviously, never missing. If the top is missing, wing it and recreate the simple Delta design. Or, now is your chance to get creative and use a design of your own. I’m kind’a partial to this one:
I used a piece of scrap, a washer, of the same thickness as a replacement for my toggle. Well, actually it is slightly thicker, but don’t go too thick or it won’t fit in the slot on the switch top. Solder the broken pieces onto the new metal.
The idea for this process came to me suddenly when I was a teenager back in the 70’s. I asked, “Dad, can I borrow the car keys?”
light bulb=”on”.
REASSEMBLY:
Finish it up with a little solder on the bolts and grind them only enough to make the clearance needed for the switch plate. Leave enough soldered bolt exposed to keep the bolts in place. Notice the height of the left bolt created by the additional countersink of the holes. This was ground to the level of the original pressed bolts.
Well, this is my finished switch.
