Page Revision: 2008/04/04 19:54
http://owwm.org/viewtopic.php?t=31028All greases start with an oil base stock and then add thickeners. The most common base is an ISO-220 stabilized oil. The most popular thickeners are metallic "soaps". Some of them are lithium, calcium, molybdenum, and boron. The metallic particles are made into a soap through a process call "saponification". Other thickeners used are microgel clays and polyurea. Both of the later are usually special application. NLGI (National Lubricating Grease Institute) is the most common classification system in use today. Grease thickness grades are from an NLGI of "000" which is pourable to a "6" which comes in brick form. NLGI grades do not overlap and there are companies that offer some greases in half grades ( NLGI 1.5). There is also an NLGI service classification that was developed for the automotive industry. Supposedly, they are working at an industrial equivalent to ASTM D-4950 which is the automotive standard.
Automotive greases and industrial greases are not equal. Many of the automotive greases have anti-wear additives that are made from Polysulfides and/or Chlorinated esters. These additives will attack "red metals" (copper) and will pit bronze and many brass alloys. Don't use automotive lubricants in machine tools or woodworking machines!
Lithium thickened grease is by far the most popular in use. Good for most applications and takes a fair amount of heat. Calcium is probably second in use. Calcium thickened grease tends to be a little more stable (stays mixed better) and can handle moisture better, but will not take much heat. Most electric motors and electro-mechanical assemblies are assembled with calcium thickened grease and not the "white lithium" that many claim. Then you go to molybdenum disulfide which is more expensive but does have better temperature handling capabilities but should not be used around brass or bronze bearings.
Most all of the "gun grease" is an NLGI #2. Lower numbered greases are used in gear boxes, central lube systems, and cartridge spindle assemblies. There are reasons for thinner greases and most of them are very valid. Just because a machine has a zerk on it, does not mean it takes #2! The manual is still the best place to look.
| Velocite #6 | ISO - 10 | |
| Velocite #10 | ISO -22 | |
Other recommendations seem less clear. For example, for Oliver machines with open, oil bath bearings, speeds < 4,000 rpm. Dev and others have recommended DTE light or Vactra #1, both ISO 32 oils. Oliver literature recommends Vactra heavy medium oil. Vactra heavy medium oil seems to translates to Vactra #2 an ISO of 68. This comes from the Mobile literature and the PM site. I’m using Vactra #2 for my 116d and 166.
- drill press spindles
- drill press rack
- machine ways
- variable speed pulleys
- drip rates
- exchange frequency
- capacities
