Page Revision: 2010/06/28 14:46
pulley side
FORMATTER ERROR (Malformed Image Tag)The cutterhead and serrated infeed and neoprene out feed rollers are identical to the K2100. Cutterhead bearings are WC88504. Feed rollers ride on flanged bronze bearings. 4 compression springs and screws provide feed roller tension. The steel chipbreaker is a separate from the sheet metal top cover. The gear and pulley side covers and 2 base cover plates are also sheet metal.
picChipbreaker
Chipbreaker
inside
Inside cabinet view showing motor pulley arrangementThe gear and pulley side covers and 2 base cover plates are also sheet metal.
