Page Revision: 2010/06/28 14:50
Another inside view with sheet metal covers removed.The pulley set up from motor to planer is the same as the K2100. A 6” pulley from the motor to a 3” pulley drives the cutterhead at 3600 rpm. A 1-1/2” pulley mounted on the motor shaft to a 7” pulley drives the feed rollers by way of a sprocket and chain on the gear side.
FORMATTER ERROR (Malformed Image Tag)
Pinion bracket shown on top of casting.The cutterhead and serrated infeed and neoprene out feed rollers are identical to the K2100. Cutterhead bearings are WC88504. Feed rollers ride on flanged bronze bearings. 4 compression springs and screws provide feed roller tension. The steel chipbreaker is a separate from the sheet metal top cover. The gear and pulley side covers and 2 base cover plates are also sheet metal.
picChipbreaker
Chipbreaker
inside
Inside cabinet view showing motor pulley arrangementThe gear and pulley side covers and 2 base cover plates are also sheet metal.
