Page Revision: 2008/05/10 15:08
by Bill NanceIntroduction
Parks Model 95 Parts Index
| A26 | Head Ball Bearing | .75"ID | 2 | |
| A28 | Head with Shaft | .75"OD | 1 | |
| A29 | Slotted Head set screw | .75"OD | 1 | |
| A30 | | .75"OD | 1 | |
