Page Revision: 2008/05/11 00:19
Parks Model 95 Parts Index
| A43 | Table | - | 1 | |
| A50 | Spring Collar | - | 6 | |
| A51 | Compression Spring | - | 1 | |
| A52 | Roll Bearing Stud | 1.25" | 1 | |
| A53 | Pressure Bar Stud | 1.25" | 1 | |
| A54 | Smooth Feed Roll Bearing | 1.25" | 1 | |
| A55 | Stud Collar | 1.25" | 1 | |
| A56 | Fluted Feed Roll Bearing | 1.25" | 1 | |
| A57 | Bearing Cap Stud | 1.25" | 1 | |
| A58 | Bearing Cap | 1.25" | 1 | |
| A59 | Left Side Casting | 1.25" | 1 | |
| A60 | | 1.25" | 1 | |
