Page Revision: 2008/05/11 00:26
Parks Model 95 Parts Index
| A43 | Table | - | 1 | |
| A55 | Stud Collar | 1.25" | 2 | part of pressure bar stud assembly |
| A57 | Bearing Cap Stud | - | 2 | 5/16 18 threads |
| A59 | Left Side Casting | 1.25" | - | |
| A60 | | 1.25" | 1 | |
