Page Revision: 2008/05/19 01:59
by Bill Nance
UNDER CONSTRUCTION
Parks Model 95 Parts Index
| A3 | Hollow Head Set Screw | 3/16 head, 3/8x3/8 | ?? | 3/8 16 thread |
| A13-20 | Lower Gear Shaft Bearing | .75"ID | 1 | part of gear shaft assembly |
| A13 | Lower Gear Shaft Bearing | - | |
| A14 | 88 Tooth Gear, Plain Hub | .75"ID | 1 | |
| A15 | Short Gear Shaft | .50"OD and .75"OD | 1 | early style |
| A15 | Short Gear Shaft | - | 1 | later style |
| A16 | Gear Shaft Bearing | .50"ID | 1 | |
| A18 | Gear Shaft Bearing | .75"ID | 2 | |
| A19 | Long Gear Shaft | .50"OD and .75"OD | 1 | |
| A20 | 128 Tooth Gear | .75"ID | 1 | |
| A27 | Head Shaft Spacer | | 1 | |
| A37 | Hood Stud | - | 2 | |
| A43 | Table | - | 1 | |
| A50 | Spring Collar | - | 6 | |
| A63 | Shaft Collar | 5/8"ID | 4 | |
| A73 | Jam Nut 5/16" thick | 5/16" thick | 2 | for pressure bar mount |
| A74 | Jam Nut 3/16" thick | 3/16" thick | 6 | for roll bearing and pressure bar studs |
| na | Drain Plug | - | 1 | |
