Page Revision: 2008/05/12 00:09
UNDER CONSTRUCTION
Parks Model 95 Parts Index
| A3 | Hollow Head Set Screw | 3/16" head | - | |
| A15 | Short Gear Shaft | .50"OD and .75"OD | 1 | early style |
| A15 | Short Gear Shaft | - | 1 | later style |
| A43 | Table | - | 1 | |
| na | Drain Plug | - | 1 | |
