Page Revision: 2008/05/10 13:24
by Bill NanceIntroduction
Parks Model 95 Parts Index
| A2 | Shaft Collar | .75" ID, 1.25" OD | 3 |
| A3 | Hollow Head Set Screw | 3/16" | ? | |
| A4 | 12 Tooth Sprocket | .75" ID, 1.37" OD | 2 | 2.25" exterior sprocket diameter |
| A6 | | .75" ID, 1.25" OD | 3 | |
| A7 | | .75" ID, 1.25" OD | 3 | |
| A8 | | .75" ID, 1.25" OD | 3 | |
| A9 | | .75" ID, 1.25" OD | 3 | |
| A10 | | .75" ID, 1.25" OD | 3 | |
