Page Revision: 2013/10/28 11:32
by Bill NanceIntroduction
1949 Operating Instructions and Parts List for Parks 12" Thickness Planer found in the OWWM Publication Reprints. Missing parts or photos were kindly provided by Doug Rewerts, resident OWWM Parks guru. Wiki contributors are encouraged to edit/replace with individual parts as available/appropriate, but are also requested asked to please indicate in the table's comments section any information that references a different operating manual.
Parks Model 95 Parts Index
| Part# | Part Name (click part for photo) | Dimensions | Qty | Comments |
| A3 | Hollow Head Set Screw | 3/16 head, 3/8x3/8 | ?? | 3/8 16 thread |
| A13-20 | Lower Gear Shaft Bearing | .75"ID | 1 | part of gear shaft assembly |
| A13 | Lower Gear Shaft Bearing | - | |
| A14 | 88 Tooth Gear, Plain Hub | .75"ID | 1 | |
| A15 | Short Gear Shaft | .50"OD and .75"OD | 1 | early style |
| A15 | Short Gear Shaft | - | 1 | later style |
| A16 | Gear Shaft Bearing | .50"ID | 1 | |
| A18 | Gear Shaft Bearing | .75"ID | 2 | |
| A19 | Long Gear Shaft | .50"OD and .75"OD | 1 | |
| A20 | 128 Tooth Gear | .75"ID | 1 | |
| A27 | Head Shaft Spacer | | 1 | |
| A37 | Hood Stud | - | 2 | |
| A43 | Table | - | 1 | |
| A50 | Spring Collar | - | 6 | |
| A63 | Shaft Collar | 5/8"ID | 4 | |
| A73 | Jam Nut 5/16" thick | 5/16" thick | 2 | for pressure bar mount |
| A74 | Jam Nut 3/16" thick | 3/16" thick | 6 | for roll bearing and pressure bar studs |
| na | Drain Plug | - | 1 | |
