Page Revision: 2008/04/08 00:48
Planer Knife Grinding and Jointing¶
Some planer manufacturers offered as an option with their machines a knife grinding and jointing attachment to allow the cutterhead knives to be sharpened in place. A threaded bar is mounted on top of the jointer, to which the grinder attachment or the jointer attachment is affixed. The attachment is then lowered to the correct location above the cutterhead. Typically a handle is used to manually turn the bar, causing the jointing stone or grinder to move across the cutterhead blade(s).
It is a two step process, although there is some controversy which to do first, or even if both steps are necessary. Others feel that when the blades become dull it is much quicker to simply replace them with a set of sharp spares, and that the jointing process after the knives are sharpened will damage the knives, despite what the manuals say. To get a knife grinder to work will take some precision setup with a dial indicator to make the bar EXACTLY parallel to the center of the cutterhead.{Reference:http://owwm.org/viewtopic.php?t=22396|http://owwm.org/viewtopic.php?t=22396} Plus you need courage to lower that jointing stone onto the spinning cutterhead the first time, it can seem very intimidating.
- The knives are jointed simultaneously using the jointer head, with the machine running(!), until a silver line is seen on all knives.
- The knives are slowly ground one at a time to the silver head using the grinding head.
Using the jointing attachment ensures that all blades are at the exact same height, meaning they will all share the work equally rather than relying most on the highest blade. This does not take into consideration bearing play and such but will give you a very nice cut pattern. {Reference:http://owwm.org/viewtopic.php?t=14882|http://owwm.org/viewtopic.php?t=14882}
The Powermatic 225 24" planer manual
here recommends jointing first, then grinding. The Yates American J-180 18" planer manual
here recommends the opposite order, grinding first then jointing.
This starts to get confusing as you read more. And it can't be that complicated. No two manuals write this up the same. Even the PM manuals have different procedures at different points of evolution. Lot's of differences of opinions. There's also the debate of which do you do first joint or grind? Some folks say to grind to the joint and some say you absolutely must joint after the grind.
Grinding Process Details
The grinding bar does need to be aligned precisely. Alignment is critical for proper results.
For grinding, the cutterhead is indexed to the proper angle for the first blade and the cutterhead locked into place. The grinding wheel is lowered onto one end of the blade, until sparks just start to fly, and then cranked across the blade. Without changing the height of the grinding wheel the head is next indexed to the second blade and the process repeated. Same for the remaining blade/blades. Blades are ground stationary, one at a time, and all blades are ground before the grinding wheel is sequentially lowered. This process is repeated until all the blades are properly ground. On a cutter head that has three knifes expect to have to make 3-5 passes on each knife to get a proper grind. Thus it may need about 15 passes with the grinder, total. Each pass takes 15 seconds or so. Pretty fast process.
Jointing process Details
The jointing is faster than the grinding. Also, you don’t absolutely have to joint the knifes, you could just grind. To joint, the grinding attachment is changed for the jointing attachment and the cutter head is brought up to speed. Now here is where it gets intimidating, the first time. With the cutterhead spinning at speed the jointer attachment/stone is lowered into the spinning head. Idea is to very slowly lower the stone until just a faint whisper of stone on metal blades is heard. If the crank on the grinding bar is properly cleaned, adjusted and lubricated, this goes very smoothly. Although it sounds intimidating, in reality it’s quite slick. The jointing stone is cranked across the length of the spinning cutterhead and the results checked. You don't really want sparks here, it's more a whisper with a hint of a spark. The jointing stone is then lowered in steps until just a thin line appears at the leading edge of the knives. This is the joint and is in essence a blunting of the bevel edge. This process leaves all knifes at the same height and adds strength to the bevel. {Reference:http://owwm.org/viewtopic.php?t=22396|http://owwm.org/viewtopic.php?t=22396}
Advantages and Disadvantages¶
First time through this process there will be a learning curve, indeed it is time consuming initially. With practice, it can be done in under 20 minutes, including dragging out the equipment if required and setup. It really is very efficient, being able to quickly grind and joint the knifes is a huge time saver. Plus, it is possible to joint the blades quickly several times before needing to regrind.
Advantages are:
- No knife send out.
- Little down time
- All knifes are at precisely the same height
There are proponents of only grinding and of grinding and jointing. Good arguments in both camps. I started with just grinding in the machine. I subsequently added a jointing attachment and much prefer the grinding/jointing process.
You can get the knives pretty close by hand setting with a dial gauge. Even better is to grind the knives on the machine. A level above this is to joint the knifes. Some people feel that the jointing process also gives better finish results with the cut. Others disagree and feel that the process damages the knife edge. Truth is, it depends on how well it is done.{Reference:http://owwm.org/viewtopic.php?t=22396|http://owwm.org/viewtopic.php?t=22396}
A number of questions related to setting the correct bevel angles on the process have been raised, but not completely answered in
this thread.
