Page Revision: 2009/02/10 11:23
Powermatic changed their serial numbering system several times over the years, and the timing varied depending on the type of machine. Therefore, interpreting a serial number requires knowledge of the machine type.
Single-End Tenoners
| Format | Years | Comments |
| | | Model 2 |
| | 1948 to 1953 | This model did not have serial numbers. |
| | | Model 2A |
| N-nnnn | 1955 to 1964 | The "N" is the units digit of the year, beginning in 1955. The "nnnn" is the number of the machine for that year. |
| 6N-nnnn | 1965 to 1968 | The "N" is the units digit of the year, beginning in 1965. The "nnnn" is the number of the machine for that year. |
| N28-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| NN32-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Mortisers
| | | Model 2A Chain |
| | | Model 15 Chain |
| 2nnn | 1953 to 1955 | The "nnn" is the number of the machine within this version. |
| | 1956 to 1960 | This model did not have serial numbers. |
| | 1960 to ???? | This model did not have serial numbers. |
| 2nnn | 1948 to 1955 | The "nnn" is the number of the machine within this version. Beginning year (1948) is estimated. |
| N40-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| NN40-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Wood Lathes
| | | Model 45 |
| | 1960 to 1964 | The serial numbering is unknown. |
| N-1nnn | 1965 to 1968 | The "N" is the units digit of the year, beginning in 1955. The "nnn" is the number of the machine for that year. |
| N45-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| NN45-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
| | | Model 90 |
| 0-nnnn | 1955 to 1968 | The "nnnn" is the number of the machine within this version. |
| N90-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| NN90-nnnn | 1978 to ???? | The "NN" is the first two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Jointers
===Scroll Saws===
Spindle Shaper
===Sanders===
Drill Presses
===Tilting Arbor Saw===
Wood-cutting Band Saws¶
===Metal-cutting Band Saws===
Planers
