Page Revision: 2025/06/12 03:08
Updated Powermatic Serial Numbers.
| Format | Years | Comments |
| mnnn | 1953—55 | "m" is a digit that varied according to machine type. "nnn" is a number. |
| N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| 6N-nnnn | 1965—68 | "N" is the units digit of the year, beginning in 1965. "nnnn" is a number. |
| NMM-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NNMM-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Examples
Another Model 60 jointer has
Caveats
Band Saws, Wood-Cutting¶
| | | Model 80 |
| N-nnnn | 1955—?? | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| | | Model 81 |
| N-nnnn | 1960—68 | "N" is the units digit of the year, beginning in 1960. "nnnn" is a number. |
| N81-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN81-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 140 |
| Model 141 |
| N-nnnn | 1961—68 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| N41-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN41-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Band Saws, Metal-cutting¶
| Model 2 |
| N02-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| Model 5 |
| N-nnnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is a number. |
| N05-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| Model 6 |
| N06-nnnn | 1970—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is a number. |
| Model 8 |
| N08-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is a number. |
| Model 83 (Friction cutting) |
| No serial numbers. |
| Model 85 |
| Model 86 |
| N-nnn | 1959—?? | "N" is the units digit of the year, beginning in 1959. "nnn" is a number. |
| Model 87 |
| N87-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN87-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 88 |
| N88-nnnn | 1974—78 | "N" is the units digit of the year, beginning in 1974. "nnnn" is a number. |
| NN88-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 89 |
| N89-nnnn | 1969—?? | "N" is the units digit of the year, beginning in 1969. "nnnn" is a number. |
Drill Presses
| Model 1100 |
| N-nnnn | 1955—63 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| Model 1150 |
| N-0nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is a number. |
| N15X-nnnn | 1968—76 | "N" is the units digit of the year, beginning in 1968. "X" is the letter V or S. "nnnn" is a number. |
| Model 1150A |
| N15X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is a number. |
| NN15X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is a number. |
| Model 1200 |
| N-1nnn | 1955—64 | "nnnn" is a number. |
| NN-nnnn | 1965—68 | "NN" is the last two digits of the year, beginning in 1965. "nnnn" is a number. |
| N20X-nnnn | 1968—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is a number. |
| NN20X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is a number. |
Jointers
| Model 50 (6 inch) |
| 11nnn | 1955—60 | "nnn" is a number. |
| N-nnnn | 1960—65 | "N" is the units digit of the year, beginning in 1960. "nnn" is a number. |
| N50-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN50-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 60 (8 inch) |
| 3nnn | 1957—1960 | "nnn" is a number. |
| N-nnnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnnn" is a number. |
| N61-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN61-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is a number. |
Lathes, Wood
| Model 45 |
| N-1nnn | 1960—65? | "N" is the units digit of the year, beginning in 1960. "nnn" is a number. |
| N45-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN45-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 90 |
| 0-nnnn | 1955—64 | "nnnn" is a number. |
| 6N-nnnn | 1965—67 | "N" is the units digit of the year, beginning in 1965. "nnnn" is a number. |
| N90-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN90-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is a number. |
Mortisers
| Model 2A Chain |
| 1948—53 | According to Powermatic this model did not have serial numbers, but we have seen at least one example that did (S/N 2050). |
| Model 15 Chain |
| 2nnn | 1953—55 | "nnn" is a number. |
| Model 30 Hydraulic Chain |
| Model 40 Hydraulic Chain |
| Model 41 Hydraulic Chain |
| Model 5 Hydraulic Hollow Chisel |
| Model 10 Hollow Chisel |
| 2nnn | 1948—55 | "nnn" is a number. Beginning year (1948) is estimated. |
| N40-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN40-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Planers
| Model 2A (20 inch) |
| Model 3A (24 inch) |
| Model 12 (12 inch) |
| nnnn | 1950—?? | "nnnn" is a number. |
| Models CD 16, CE 16, CS 16 (16 inch) |
| Model E 16 (16 inch) |
| nnnn | 19??—?? | "nnnn" is a number, beginning with 7001. |
| Model 100 (12 inch) |
| nnnn | 1955—55 | "nnnn" is a number, beginning with 6200. |
| N00-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN00-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 160 (16 inch) |
| N-nnnn | 1959—67 | "N" is the units digit of the year, beginning in 1959. "nnnn" is a number. |
| N60-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN60-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 180 (18 inch) |
| N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnn" is a number. |
| N80-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN80-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 220 (20 inch) |
| nnnn | 1952—55 | "nnnn" is a number, beginning with number 5100. |
| Model 221 (20 inch) |
| N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number, beginning with 5525. |
| N22-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN22-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 224 (24 inch) |
| nnnn | 1955—57 | "nnnn" is a number, beginning with number 8001. |
| Model 225 (24 inch) |
| nnnn | 1957—60 | "nnnn" is a number, beginning with number 8360. |
| N-nnnn | 1960—67 | "N" is the units digit of the year, beginning in 1965. "nnnn" is a number. |
| N25-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN25-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Sanders¶
| Model 30 |
| N30-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| Model 30A |
| N30Annnn | 1969—77 | "N" is the units digit of the year, beginning in 1969. "nnn" is a number. |
| NN30-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 30B |
| Model 33 |
| N33-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| Model 33B |
| NN33-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 35 |
| N35-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| Model 35B |
| NN35-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Scroll Saws
| Model 95 |
| N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnnn" is a number. |
| N95-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN95-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Spindle Shaper
| Model 25 |
| N-nnnn | 1961—65 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| Model 26 |
| N26-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN26-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Tilting Arbor Saw (Tablesaw)
| Model 62 |
| N-nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnn" is a number. |
| N62-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN62-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 65 |
| N-nnn | 1955—65 | "N" is the units digit of the year, beginning in 1955. "nnn" is a number. |
| NN-nnn | 1965—?? | "NN" is the last two digits of the year, beginning in 1965. "nnn" is a number. |
| Model 66 |
| 66-nnn | 1965—68 | "nnn" is a number. |
| N66-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN66-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 68 |
| N68-nnnn | 1972—78 | "N" is the units digit of the year, beginning in 1972. "nnnn" is a number. |
| NN68-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| Model 70 |
| 1nnn | 1954—55 | "nnn" is a number. |
| N-nnnn | 1955—60 | "nnnn" is a number. |
| Model 71 |
| N-nnn | 1960—?? | "N" is the units digit of the year, beginning in 1960. "nnn" is a number, beginning with "600" in 1960. |
| Model 72 |
| N-nnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnn" is a number. |
| N72-nnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnn" is a number. |
| NN72-nnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnn" is a number. |
Tenoners, Single-End
| Model 2 |
| Model 2A |
| N28-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| NN32-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
