Page History: Pre History Of Band Saws
Page Revision: 2008/07/25 10:58
The
first American bandsaw patent was granted to Benjamin Barker of Ellsworth, Maine, in January of 1836. Barker patented the basic concept of the bandsaw. There was obvious prior art, but before July 1836 there was no review process for patent applications. Barker's machine used a blade 34 feet long, 9 inches wide, and one twelfth of an inch thick, or about the thickness of a thin-kerf circular saw blade. The wheel's diameter was five feet. Notice how the frame of the saw is not a C-frame but more of an I-frame. That reduces the saw's horizontal capacity by half, but with five-foot wheels it hardly matters.
The
next bandsaw patent came along only a month later, granted to one William Cary of Poughkeepsie.
Wow. Just wow.
Given the problems with blades, some applied their throbbing brains to alternative approaches to making a continuous-cutting scrollsaw replacement.
Here's one solution from 1838:
This type of saw was common enough to merit its own name: the annular saw. One was manufactured by Goodspeed & Wyman ca. 1870, just in time to be knocked off the market by the newly practical bandsaw.
After those two 1836 patents,
the next true bandsaw patent came in 1849, granted to rule maker and sawmill maker Lemuel Hedge. This design looks pretty normal. The saw has upper guides, albeit odd-looking.
In 1857
Hedge's patent was reissued. Hedge was deceased by that time, and the reissued patent was assigned to William P. Wood and Samuel De Vaughan of Washington DC. We don't know anything about these guys other than the patents they were granted, but it is at least possible they manufactured the saw, otherwise why would they go to the expense of a reissue? Further research is warranted.
In 1851 Hedge received
another bandsaw patent, this time for a radically different design.
Another dead end is this
decidedly odd idea patented in 1858 by one Harvey Brown of New York City:
Next in our bandsaw freakshow is a bandsaw that uses a chainsaw blade,
patented in 1863 by New Yorker George Kammerl:
In 1866, New Yorker Paul Pryibil
patented some bandsaw features
Pryibil's patent covered an upper blade guide design that looks rather impractical because it consumes too much vertical capacity. More importantly, the patent covered the use of a spring to make a yielding mount for the upper wheel. The patent's importance in itself is modest; we skipped over some more important bandsaw patents because of insufficient entertainment value. But Pryibil's patent is notable because it is, so far as we know, the first patented bandsaw that actually saw commercial production.
Although the saw above does not exactly match the patent drawing, it uses the patented features and carries the 1866 patent date.
One of the best, simplest and commonest tools is the band saw, and for some singular reason this is hardly ever used in America. It consists merely of an endless saw passing over two pulleys, one above the other, by which it is kept in tension and driven. One pulley is made adjustable so as to regulate the amount of tension, and is furnished either with a spring or a counterweight to allow of the expansion and contraction that necessarily occur from the heating and cooling of the saw when in use, without either causing the band to become loose and slip, or to snap from over-tension. The advantages of this tool are most obvious: as the motion is always in the cutting direction no time is lost in reciprocations, and for the same reason much more delicate work can be done with it, as there is no alteration of strain which would tend to break thin portions of wood, and, moreover, a fan is rendered unnecessary, as all the saw dust is carried down beneath the table. The pulleys generaliy have leather coating for the saw band to run on, though this is not always the case. The English are certainly ahead of us on this tool, for if, as I have heard it said, we have not been able to make it go, they have, and there is no shop of any consequence without it.
With the first known ad and commercially manufactured bandsaw, the prehistory ends. See the
Early History of Band Saws for the continuation of this story.
