Page History: Patching sheet metal holes using low temp solder.
Page Revision: 2008/04/18 23:32
before and after
Getting Started
Prep
A filler for the holes is needed, I used some soft copper from a pipe hanging fixture, hammered flat it was a perfect thickness for this application. For thicker sheet metal, an old copper penny might be a quick and cheap source of material. Using lineman's pliers, the plug is cut to shape, slowly snipping into a circle. When I got to where it fit, I pressed it into the hole using the same pliers.
Soldering
Filing and Sanding¶
The finished product
Remember:Do all metal hammering and straightening first.
Clean area well.
