Page Revision: 2016/08/23 15:57
Table of Contents [Hide/Show]
      1000 12" Thickness Planer
      Jointer Model 103.23340
      15" Drill Press
      17" Drill Press
      10" Grinder
      14" Bandsaw, Wood Cutting
      Delta 900 - Radial Arm Saw
      Delta/Rockwell 22-101 Planer
      46-111 14/11 Inch Lathe
      43-503 Pin Router
      =Carbide Grinder
      192 18" Band Saw
      M2 Bandsaw Wheels
Porter Cable
      G4 Belt Sander
Powermatic
      141 Bandsaw
       Model 100 12" planer (1958)
      Model 25 Shaper
      Model 35 Disk Sander
      Model 50 6" Jointer
      14" Wood Bandsaw
Wissota
  • Quill:
    • Upper: 88505 ND > 88505 KS
  • Pulley:
    • Upper: 88508 ND > 88508 IF
    • Lower: 88508 ND > 88508 IF
  • Lift table:
  • Spindle:
  • Cutterhead: R8ZZ both sides
  • Bullet Motor: 87504 (x2)
  • 87-010 Motor (x2):
    • Original: Norma S 3505
    • Replacement: KYK 63205
  • Arbor (x2):
15" Drill Press
  • Quill - 2x 6203
  • Pulley - 2x 6205
17" Drill Press
  • Older Style:
    • 2x 88503
  • Newer Style:
    • 2x 6203
  • 2x48" Belt Attachment
    • 2x 6203
10" Grinder
  • 2x 6206
  • Newer Style:
  • Older Style:
    • Upper wheel: 87502 (2x)
    • Lower wheel: 87504 (2x)
    • Gear case: 87016 (4x)
  • Upper wheel:
    • one 87504, one 87502
  • Lower wheel:
    • one 87506, one 87505
  • Thrust bearings: 6203
  • 6204
  • New Departure 87502
  • New Departure 87503
  • New Departure 87502 (x2)
  • Rollerhead (x4):Nachi 81004
43-503 Pin Router
  • Spindle bearings
=Carbide Grinder
  • New style:
    • 6203 x 2
  • 6203 (ODE)
  • 6204 (DE)
  • 6204 (ODE)
  • 6204 (DE)
  • Alternative: 6203 (x2)
    My 62-110 used these.
  • 62-110 scroll saw motor
    NACHI 6203zz no extended race
  • Motor (1ph and 3ph):
    • Arbor side: 88504
  • Rollerhead (x4):
    • Original: Fafnir 200KDD15
    • Replacement: Nachi 81004
192 18" Band Saw
    • 2x 6306
  • 2x 6204
M2 Bandsaw Wheels
Porter Cable
G4 Belt Sander
  • Motor: 2x 6205
Powermatic
141 Bandsaw
  • Top: 2x 6203LLNR
  • Bottom 2x 6204LLNR
  • Guides 4x 6200LL
Model 25 Shaper
  • Spindle: 1x 6205, 1x 6304
Model 50 6" Jointer
  • Cutterhead: 2x 6203
14" Wood Bandsaw
  • Pulley: 2x 6205
  • Upper Spindle: 6204-3/4
  • Shaper spindle: 6203 (x2)
Wissota
