Page Revision: 2020/05/04 16:37
Atlas
63 15" Drill Press
1000 12" Thickness Planer
- Quill:
- Upper: 88505 ND > 88505 KS
- Pulley:
- Upper: 88508 ND > 88508 IF
- Lower: 88508 ND > 88508 IF
- Lift table:
- Spindle:
Jointer Model 103.23340
- Cutterhead: R8ZZ both sides
- 87-010 Motor (x2):
- Original: Norma S 3505
- Replacement: KYK 63205
- Arbor (x2):
15" Drill Press
- Quill - 2x 6203
- Pulley - 2x 6205
17" Drill Press
- Older Style:
- Newer Style:
- 2x48" Belt Attachment
10" Grinder
14" Bandsaw, Wood Cutting¶
- Newer Style:
- Older Style:
- Upper wheel: 87502 (2x)
- Lower wheel: 87504 (2x)
- Gear case: 87016 (4x)
- Upper wheel:
- Lower wheel:
- Thrust bearings: 6203
- New Departure 87502
- New Departure 87503
- New Departure 87502 (x2)
Delta 900 - Radial Arm Saw
- Rollerhead (x4):Nachi 81004
Delta/Rockwell 22-101 Planer
46-111 14/11 Inch Lathe
43-503 Pin Router
- Spindle bearings
Carbide Grinder
10" Abrasive Cut-Off Saw
NACHI 6203zz no extended race
- Motor (1ph and 3ph):
- Arbor side: 88504
- Rollerhead (x4):
- Original: Fafnir 200KDD15
- Replacement: Nachi 81004
192 18" Band Saw¶
M2 Bandsaw Wheels¶
Porter Cable
G4 Belt Sander¶
- Motor: 2x 6205
Powermatic
141 Bandsaw¶
- Top: 2x 6203LLNR
- Bottom 2x 6204LLNR
- Guides 4x 6200LL
143 Bandsaw¶
- Top: 2x 6203LLNR
- Gear Box:
- 3x 6303LL
- 3x TRB 1220
- 3x IR 1212
- 3x IR 1216
- Guides 4x 6200LL
- Countershaft 2x 6204LLNR
Model 100 12" planer (1958)
Model 25 Shaper
- Spindle: 1x 6205, 1x 6304
Model 30 Belt/Disk Sander¶
- Quill 2x W205PP
Model 35 Disk Sander¶
Model 50 6" Jointer
Oscillating Mechanism:
- Upper (p/n 018026): 6205
- Lower (p/n 018027): 6204
14" Wood Bandsaw¶
- Pulley: 2x 6205
- Upper Spindle: 6204-3/4
- Shaper spindle: 6203 (x2)
Wissota
