Page Revision: 2020/05/04 16:37
Table of Contents [Hide/Show] Atlas 63 15" Drill Press Boice-Crane 1400 6" Jointer 1650 15" Bench Top Drill Press 1000 12" Thickness Planer Buffalo Forge No. 18 Drill Press (w/ external screw table lift) Delta Unisaw 14" Drill Press (DP220) 15" Drill Press 17" Drill Press 7" Tool Grinder 10" Grinder 14" Bandsaw, Wood Cutting 14" Bandsaw, Metal/Wood Cutting Delta/Crescent 20" Bandsaw (model 28-350 and 28-365 with rounded corner cabinet) Delta/Rockwell 8" Jointer (model 37-315) Delta/Rockwell 6" Jointer (model 37-220) Delta/Rockwell 4" Jointer (37-290, 37-110, 22-110) Delta 900 - Radial Arm Saw Delta Super 900 - Radial Arm Saw Delta/Rockwell 22-101 Planer 46-111 14/11 Inch Lathe 43-503 Pin Router Carbide Grinder 10" Abrasive Cut-Off Saw Motor: Model 93-610 (2HP, 1725 RPM, capacitor start) Motor: Model 87-310 (2HP 3 phase) Motor: Model 86-520 (1/2 HP 3 phase) Motor: 3/4 hp 1725 rpm Repulsion Induction motor: frame 180 Motor: Model 6400 - 1/3 hp 1725 rpm Repulsion Induction motor Motor: Model 62-110 - 1/3 hp 1725 rpm Capacitor Start motor Motor: Double Duty cat. V6920 - 1/2 hp 1725 rpm Capacitor Start motor: frame 165, 5/8" double-end shaft Motor: Double Duty cat. 62610 - 1/2 hp 1725 rpm Capacitor Start motor: frame 166, 5/8" double-end shaft Motor: Model 924 - 3/4 hp 1725 rpm Repulsion Induction motor Motor: Model 800 - 1/3 hp 1725 rpm Split Phase motor Delta Unisaw 14" Drill Press (DP220) 15" Drill Press 17" Drill Press 7" Tool Grinder 10" Grinder 14" Bandsaw, Wood Cutting 14" Bandsaw, Metal/Wood Cutting Delta/Crescent 20" Bandsaw (model 28-350 and 28-365 with rounded corner cabinet) Delta/Rockwell 8" Jointer (model 37-315) Delta/Rockwell 6" Jointer (model 37-220) Delta/Rockwell 4" Jointer (37-290, 37-110, 22-110) Delta 900 - Radial Arm Saw Delta Super 900 - Radial Arm Saw Delta/Rockwell 22-101 Planer 46-111 14/11 Inch Lathe 43-503 Pin Router Carbide Grinder 10" Abrasive Cut-Off Saw Motor: Model 93-610 (2HP, 1725 RPM, capacitor start) Motor: Model 87-310 (2HP 3 phase) Motor: Model 86-520 (1/2 HP 3 phase) Motor: 3/4 hp 1725 rpm Repulsion Induction motor: frame 180 Motor: Model 6400 - 1/3 hp 1725 rpm Repulsion Induction motor Motor: Model 62-110 - 1/3 hp 1725 rpm Capacitor Start motor Motor: Double Duty cat. V6920 - 1/2 hp 1725 rpm Capacitor Start motor: frame 165, 5/8" double-end shaft Motor: Double Duty cat. 62610 - 1/2 hp 1725 rpm Capacitor Start motor: frame 166, 5/8" double-end shaft Motor: Model 924 - 3/4 hp 1725 rpm Repulsion Induction motor Motor: Model 800 - 1/3 hp 1725 rpm Split Phase motor DeWalt MBC/MBF 9" Radial Arm Saws Oliver 192 18" Band Saw Parks 12" Planer M2 Bandsaw Wheels Porter Cable G4 Belt Sander Powermatic 141 Bandsaw 143 Bandsaw Model 100 12" planer (1958) Model 25 Shaper Model 30 Belt/Disk Sander Model 35 Disk Sander Model 50 6" Jointer Sprunger Bros. NDP15 Drill Press (floor and bench models) State Manufacturing & Engineering Co. B-4 Oscillating Spindle Sander and T-5 Titling Spindle Sander Walker-Turner 1180B 10" Tilting Arbor Table Saw 14" Wood Bandsaw Drill Press - Model 1100 20" Early 700 Series 1/2" Shaper Wissota 701 Series A Belt-Driven Grinder
Atlas
63 15" Drill Press
- Quill:
- Upper: 88505 ND > 88505 KS
- Pulley:
- Upper: 88508 ND > 88508 IF
- Lower: 88508 ND > 88508 IF
- Lift table:
- 87-010 Motor (x2):
- Original: Norma S 3505
- Replacement: KYK 63205
- Arbor (x2):
15" Drill Press
- Quill - 2x 6203
- Pulley - 2x 6205
17" Drill Press
- Older Style:
- Newer Style:
- 2x48" Belt Attachment
10" Grinder
14" Bandsaw, Wood Cutting¶
- Newer Style:
- Older Style:
- Upper wheel: 87502 (2x)
- Lower wheel: 87504 (2x)
- Gear case: 87016 (4x)
- Upper wheel:
- Lower wheel:
- Thrust bearings: 6203
- New Departure 87502
- New Departure 87503
- New Departure 87502 (x2)
- Rollerhead (x4):Nachi 81004
43-503 Pin Router
- Spindle bearings
Carbide Grinder
NACHI 6203zz no extended race
- Arbor (x2):
15" Drill Press
- Quill - 2x 6203
- Pulley - 2x 6205
17" Drill Press
- Older Style:
- Newer Style:
10" Grinder
- Newer Style:
- Older Style:
- Upper wheel:
- Lower wheel:
43-503 Pin Router
- Spindle bearings
Carbide Grinder
- Motor (1ph and 3ph):
- Arbor side: 88504
- Rollerhead (x4):
- Original: Fafnir 200KDD15
- Replacement: Nachi 81004
192 18" Band Saw¶
M2 Bandsaw Wheels¶
Porter Cable
G4 Belt Sander¶
- Motor: 2x 6205
Powermatic
141 Bandsaw¶
- Top: 2x 6203LLNR
- Bottom 2x 6204LLNR
- Guides 4x 6200LL
143 Bandsaw¶
- Top: 2x 6203LLNR
- Gear Box:
- 3x 6303LL
- 3x TRB 1220
- 3x IR 1212
- 3x IR 1216
- Guides 4x 6200LL
- Countershaft 2x 6204LLNR
Model 25 Shaper
- Spindle: 1x 6205, 1x 6304
Model 30 Belt/Disk Sander¶
- Quill 2x W205PP
Model 35 Disk Sander¶
Model 50 6" Jointer
Oscillating Mechanism:
- Upper (p/n 018026): 6205
- Lower (p/n 018027): 6204
14" Wood Bandsaw¶
- Pulley: 2x 6205
- Upper Spindle: 6204-3/4
- Shaper spindle: 6203 (x2)
Wissota
