Page Revision: 2022/02/19 00:55
Table of Contents [Hide/Show]
Atlas
      63 15" Drill Press
      1000 12" Thickness Planer
      15" Drill Press
      17" Drill Press
      10" Grinder
      14" Bandsaw, Wood Cutting
      Delta 900 - Radial Arm Saw
      Red Star Pre-Delta Radial Arm Saw
      Delta/Rockwell 22-101 Planer
      46-111 14/11 Inch Lathe
      43-503 Pin Router
      Carbide Grinder
      Delta/Rockwell 10" Abrasive Cut-Off Saw
      15" Drill Press
      17" Drill Press
      10" Grinder
      43-503 Pin Router
      Carbide Grinder
      Delta/Rockwell 10" Abrasive Cut-Off Saw (No. 1600)
      192 18" Band Saw
      M2 Bandsaw Wheels
Porter Cable
      G4 Belt Sander
Powermatic
      141 Bandsaw
      143 Bandsaw
       Model 100 12" planer (1958)
      Model 25 Shaper
      Model 30 Belt/Disk Sander
      Model 1200 20" Drill Press (early model)
      Model 50 6" Jointer
      B-4 Oscillating Spindle Sander and T-5 Titling Spindle Sander
      14" Wood Bandsaw
Wissota
Atlas
63 15" Drill Press
  • Quill: 6202-5/8 bore, Spindle pulley: 6204 & 6205
  • Quill:
    • Upper: 88505 ND > 88505 KS
  • Pulley:
    • Upper: 88508 ND > 88508 IF
    • Lower: 88508 ND > 88508 IF
  • Lift table:
  • Bullet Motor: 87504 (x2)
  • 87-010 Motor (x2):
    • Original: Norma S 3505
    • Replacement: KYK 63205
  • Arbor (x2):
  • 2x 6202-10 (5/8" bore) for quill. These are not exact replacements as the original quill bearings were designed such that you could easily replace the quill with other designed for mortising or shaping, but for drill-only purposes these are suitable replacements. Original bearings' inner race is designed for a slip fit; newer 6202-5/8 bearings will have to be pressed on the spindle instead which makes the spindle non-interchangeable.
15" Drill Press
  • Quill - 2x 6203
  • Pulley - 2x 6205
17" Drill Press
  • Older Style:
    • 2x 88503
  • Newer Style:
    • 2x 6203
  • 2x48" Belt Attachment
    • 2x 6203
10" Grinder
  • 2x 6206
  • Newer Style:
  • Older Style:
    • Upper wheel: 87502 (2x)
    • Lower wheel: 87504 (2x)
    • Gear case: 87016 (4x)
  • Upper wheel:
    • one 87504, one 87502
  • Lower wheel:
    • one 87506, one 87505
  • Thrust bearings: 6203
  • 6204
  • New Departure 87502
  • New Departure 87503
  • New Departure 87502 (x2)
  • Rollerhead (x4):Nachi 81004
  • Model 40A 1.5HP Motor
    Arbor blade side bearing: Norma 205PP ID,OD,W = 25mm, 52mm, 15mm
    Back Side Motor bearing: Norma 303PP ID,OD,W = 17mm, 47mm, 14mm
43-503 Pin Router
  • Spindle bearings
Carbide Grinder
  • New style:
    • 6203 x 2
  • Arbor: MRC203FSF x 2 (87503 equivalent - extended inner race)
  • 6203 (ODE)
  • 6204 (DE)
  • 6204 (ODE)
  • 6204 (DE)
  • 87504 (x2)
  • Alternative: 6203 (x2)
    My 62-110 used these.
  • 62-110 scroll saw motor
    NACHI 6203zz no extended race
  • Arbor (x2):
15" Drill Press
  • Quill - 2x 6203
  • Pulley - 2x 6205
17" Drill Press
  • Older Style:
    • 2x 88503
  • Newer Style:
    • 2x 6203
    • 2x 6203
10" Grinder
  • 2x 6206
  • Newer Style:
  • Older Style:
  • Upper wheel:
  • Lower wheel:
  • 6204
43-503 Pin Router
  • Spindle bearings
Carbide Grinder
  • New style:
    • 6203 x 2
  • 5/8" Arbor Assembly: 87503 (x2) (extended inner race faces out on both sides)
  • 6203 (ODE)
  • 6204 (DE)
  • 6204 (ODE)
  • 6204 (DE)
  • 87504 (x2)
  • Motor (1ph and 3ph):
    • Arbor side: 88504
  • Rollerhead (x4):
    • Original: Fafnir 200KDD15
    • Replacement: Nachi 81004
192 18" Band Saw
    • 2x 6306
  • 2x 6204
M2 Bandsaw Wheels
Porter Cable
G4 Belt Sander
  • Motor: 2x 6205
Powermatic
141 Bandsaw
  • Top: 2x 6203LLNR
  • Bottom 2x 6204LLNR
  • Guides 4x 6200LL
143 Bandsaw
  • Top: 2x 6203LLNR
  • Gear Box:
    • 3x 6303LL
    • 1x RB012AZZ (this crosses to a NPC012RP)
    • 3x TRB 1220
    • 3x IR 1212
    • 3x IR 1216
  • Guides 4x 6200LL
  • Countershaft 2x 6204LLNR
  • Tension Adjustment Nice 603 1/4
Model 25 Shaper
  • Spindle: 1x 6205, 1x 6304
  • Idler 2x 6205LLNR (snap ring)
  • Quill 2x W205PP
  • quill: 2x 6206
  • idler: 2x 6205, 1x 6204
  • spindle: 2x 6007
Model 50 6" Jointer
  • Cutterhead: 2x 6203
Oscillating Mechanism:
  • Upper (p/n 018026): 6205
  • Lower (p/n 018027): 6204
14" Wood Bandsaw
  • Pulley: 2x 6205
  • Upper Spindle: 6204-3/4
  • Shaper spindle: 6203 (x2)
Wissota
