Page Revision: 2011/09/05 13:26
- Quill:
- Upper: 88505 ND > 88505 KS
- Pulley:
- Upper: 88508 ND > 88508 IF
- Lower: 88508 ND > 88508 IF
- Lift table:
- Spindle:
- Cutterhead: R8ZZ both sides
17" Drill Press
10" Grinder
14" Bandsaw, Wood Cutting¶
- Newer Style:
- Upper wheel: 6202LL Nachi
- Lower wheel: 6204LL Nachi
- Older Style:
- Upper wheel: 87502
- Lower wheel: 87504
- Guides: 6200LL Nachi
- Upper wheel:
- Lower wheel:
- Thrust bearings: 6203
- New Departure 87502
- New Departure 87503
- New Departure 87502 (x2)
Super 900 - Radial Arm Saw
- Rollerhead (x4):Nachi 81004
- 87-010 Motor (x2):
- Original: Norma S 3505
- Replacement: KYK 63205
- Arbor (x2):
Delta/Rockwell 22-101 Planer
46-111 14/11 Inch Lathe
- Motor (1ph and 3ph):
- Arbor side: 88504
- Rollerhead (x4):
- Original: Fafnir 200KDD15
- Replacement: Nachi 81004
192 18" Band Saw¶
M2 Bandsaw Wheels¶
==Porter Cable==
14" Wood Bandsaw¶
- Pulley: 2x 6205
- Upper Spindle: 6204-3/4
- Shaper spindle: 6203 (x2)
