Page Revision: 2013/10/28 12:45
Table of Contents [Hide/Show]
      Jointer Model 103.23340
      15" Drill Press
      17" Drill Press
      10" Grinder
      14" Bandsaw, Wood Cutting
      Super 900 - Radial Arm Saw
      Delta/Rockwell 22-101 Planer
      46-111 14/11 Inch Lathe
      192 18" Band Saw
      M2 Bandsaw Wheels
Porter Cable
      G4 Belt Sander
Powermatic
      141 Bandsaw
      14" Wood Bandsaw
  • Quill:
    • Upper: 88505 ND > 88505 KS
  • Pulley:
    • Upper: 88508 ND > 88508 IF
    • Lower: 88508 ND > 88508 IF
  • Lift table:
  • Spindle:
  • Cutterhead: R8ZZ both sides
  • Bullet Motor: 87504 (x2)
  • 87-010 Motor (x2):
    • Original: Norma S 3505
    • Replacement: KYK 63205
  • Arbor (x2):
15" Drill Press
  • Quill - 2x 6203
  • Pulley - 2x 6205
17" Drill Press
  • Older Style:
    • 2x 88503
  • Newer Style:
    • 2x 6203
  • 2x48" Belt Attachment
    • 2x 6203
10" Grinder
  • 2x 6206
  • Newer Style:
  • Older Style:
    • Upper wheel: 87502 (2x)
    • Lower wheel: 87504 (2x)
    • Gear case: 87016 (4x)
  • Upper wheel:
    • one 87504, one 87502
  • Lower wheel:
    • one 87506, one 87505
  • Thrust bearings: 6203
  • New Departure 87502
  • New Departure 87503
  • New Departure 87502 (x2)
  • Rollerhead (x4):Nachi 81004
  • 6203 (ODE)
  • 6204 (DE)
  • 6204 (ODE)
  • 6204 (DE)
  • Alternative: 6203 (x2)
    My 62-110 used these.
  • Motor (1ph and 3ph):
    • Arbor side: 88504
  • Rollerhead (x4):
    • Original: Fafnir 200KDD15
    • Replacement: Nachi 81004
192 18" Band Saw
    • 2x 6306
  • 2x 6204
M2 Bandsaw Wheels
Porter Cable
G4 Belt Sander
  • Motor: 2x 6205
Powermatic
141 Bandsaw
  • Top: 2x 6203LLNR
  • Bottom 2x 6204LLNR
  • Guides 4x 6200LL
14" Wood Bandsaw
  • Pulley: 2x 6205
  • Upper Spindle: 6204-3/4
  • Shaper spindle: 6203 (x2)
