Welcome
Guest
Wiki Home
VintageMachinery.org Home
OWWM.org Home
Donate
Search the Wiki:
Main Page
Random Page
Create a new Page
All Pages
Categories
File Management
Create Account
Help Topics
Discuss (0)
View Page Code
History
Triple
Print
RSS
Modified on 2008/03/29 23:25
by
Dan McCallum
Categorized as
Uncategorized
Early History Of Band Saws
(8)
Pre History Of Band Saws
Cincinnati Electric Tool Co.
Triple
[X]
Motor Manufacturers
New Departure Bearings
Decals - Hall & Brown Woodworking Machine Co.
Replacement Bearing List
Rebuilding A Powermatic 45 Wood Lathe
Triple
Single Pole is similar to a light switch. Only one lead is disconnected from the power source. Typically, this would be the Hot (Black) lead. However in the case of miswired circuits, non-polarized plugs, etc., the Hot lead may end up wired to the motor and only the Neutral (White) lead being controlled. Single Pole controls are best NOT used in motor start circuits.
Double Pole is common on Single Phase power where both the Hot (Black or Red) and Neutral (White) are disconnected from the power source. This is good practice as it leaves no chance that the motor may remain energized even with the switch off.
Triple Pole (or more) would be required for Three Phase power to ensure that each of the three Hot (Black, Red & White) legs are disconnected from the power source.
ScrewTurn Wiki
FamFamFam
