Page Revision: 2008/04/01 22:53
Site of manufacture:
User’s Manual:
Casting Marks & Parts Prefixes:
Tops and Extensions:
Fence:
Fence Locking Lever Knob:
Fence Micro-Adjustment Knob:
Rear Fence Rail Locking Thumb Nut:
Fence Rails:
Miter Gage:
Blade Guards:
Cabinet:
19XX the dust door opening changed to have two 6" long tabs on the sides (one each side) and two tabs on the top 2" long. These tabs are for the dust door to rest against.
Cabinet Bottom:
Dust Door:
Tilt Scale:
Switches & Switch Plates:
Motor Cover:
1939: The cast iron goose egg motor cover (LTA-474) was made available as an accessory (Cat. No. 1454). It weighs 23 pounds and held in place by four 1/4-20 X ½” self tapping hex head screws.
Handwheels:
Handwheel Tightening Knobs:
Serial Number Plate:
Base (Feet or Plinth):
Motors:
  • No. 8200 – ½ HP 1725 RPM
  • No. 8210 – ½ HP 1425 RPM
  • No. 8250 – ¾ HP 1725 RPM
  • No. 8260 – ¾ HP 1425 RPM
  • No. 8300 – 1 HP 1725 RPM
  • No. 8310 – 1 HP 1425 RPM
Three-Phase Motors:
  • No. 8400 – ¾ HP 1725 RPM
  • No. 8410 – ¾ HP 1425 RPM
  • No. 8450 – 1 HP 1725 RPM
  • No. 8460 – 1 HP 1425 RPM
  • No. 8500 – 1 ½ HP 1725 RPM
  • No. 8510 – 1 ½ HP 1425 RPM
Direct Current Motors:
  • No. 8600 – ½ HP 1725 RPM
  • No. 8610 – ½ HP 1425 RPM
  • No. 8650 – ¾ HP 1725 RPM
  • No. 8651 – ¾ HP 1425 RPM
  • No. 8700 – 1 HP 1725 RPM
  • No. 8701 – 1 HP 1425 RPM
Drive Train: All units have triple belt drives.
