Page Revision: 2008/04/02 21:57
Site of manufacture
User’s Manual
Casting Marks & Parts Prefixes
Tops and Extensions
Fence
Fence Locking Lever Knob
Fence Micro-Adjustment Knob
Rear Fence Rail Locking Thumb Nut
Fence Rails
Miter Gage
Blade Guards
Cabinet
19XX the dust door opening changed to have two 6" long tabs on the sides (one each side) and two tabs on the top 2" long. These tabs are for the dust door to rest against.
Cabinet Bottom
Dust Door
Tilt Scale
Switches & Switch Plates
Motor Cover
1939: The cast iron goose egg motor cover (LTA-474) was made available as an accessory (Cat. No. 1454). It weighs 23 pounds and held in place by four 1/4-20 X ½” self tapping hex head screws.
Handwheels
Handwheel Tightening Knobs
Serial Number Plate
Base (Feet or Plinth
Motors
  • No. 8200 – ½ HP 1725 RPM
  • No. 8210 – ½ HP 1425 RPM
  • No. 8250 – ¾ HP 1725 RPM
  • No. 8260 – ¾ HP 1425 RPM
  • No. 8300 – 1 HP 1725 RPM
  • No. 8310 – 1 HP 1425 RPM
Three-Phase Motors:
  • No. 8400 – ¾ HP 1725 RPM
  • No. 8410 – ¾ HP 1425 RPM
  • No. 8450 – 1 HP 1725 RPM
  • No. 8460 – 1 HP 1425 RPM
  • No. 8500 – 1 ½ HP 1725 RPM
  • No. 8510 – 1 ½ HP 1425 RPM
Direct Current Motors:
  • No. 8600 – ½ HP 1725 RPM
  • No. 8610 – ½ HP 1425 RPM
  • No. 8650 – ¾ HP 1725 RPM
  • No. 8651 – ¾ HP 1425 RPM
  • No. 8700 – 1 HP 1725 RPM
  • No. 8701 – 1 HP 1425 RPM
Drive Train
