Page Revision: 2009/01/25 20:29
- Type 0: No serial numbers. Early machines did not have any serial numbers.
- Type 1: The first serial number system began in 1939, although not all machines had them that year. These followed no logical pattern and were more akin to a model number than a unit-specific designation. Some of the numbers indicate the year that the model was introduced (not necessarily built) as the last two digits. See the machine-specific section below for details. Note that although the original document lists serial numbers with dashes, the numbers that were stamped onto the badges often used a space instead.
 Early Type 1 serial number tag. DP900 serial 9DP1040, contributed by Dan Hoenish. |
 Typical Type 1 serial number tags. BN905 serial 19-639, contributed by Mike Wiggins. BW740 serial 29-449 contributed by Rich McGowen. |
- In 1948 Walker-Turner was sold to Kearney & Trecker. At some point thereafter the tags were changed to read "Walker-Turner Division of Kearney & Trecker".
- Type 2: Starting in April of 1950 a new system was introduced. These new serials are formatted YYMSQD where YY is the year of manufacture, M is the type of machine, S is the specific model of machine, Q is the quarter of the year of manufacture, and D notes deviation from the standard model. For example, 52DA2A is a standard (52DA2A) single-spindle (52DA2A) 15" drill press (52DA2A) that was built in the 2nd quarter (52DA2A) of 1952 (52DA2A). Details about the second letter code ("S" above) is included in the machine type breakdown. Below is a list of the machine type code letters ("M" above) and what they stand for.
| C | Sander | | L | Lathes |
| | | S | Spindle Shaper |
- Type 3: The next serial number system was introduced in April 1953 and used through September 1956. Each machine was numbered 0000001, 0000002, etc. The type and model cannot be identified by the number alone. Machine tags used during this time included fields for both Model No. and Serial No. Almost all of the models sold during this time were introduced in 1953.
- In May of 1956 Kearney & Trecker sold its Walker-Turner Division to Rockwell. At some point thereafter the tags were changed to read "Walker-Turner Division of Rockwell". It is currently unknown if this change occurred before the start of Type 4 serial numbers.
- Type 4: The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956. Details on the two-digit prefix, when known, appear in the machine type breakdown. This system continued until Delta/Rockwell's serial number system replaced it. Walker-Turner machines with a Rockwell serial number badge should be dated according to the Delta Serial Numbers page. Most Rockwell built Walker-Turner machines came from either their Bellefountaine or Tupelo plants.
15-inch Drill Press
Type 1:
900 Series, 1940 through 1947: 9D140, 9D1040*, 9D943,
1-1140,
1-944,
1-147* While examples of serial number
9DP1040 have been entered into the Photo Index, none have been entered for 9D140, 9D1040, 9D943. This is likely a mistake in the original document.
Type 2:
50DH2E,
51DM1A,
51DJ3A,
Type 3:
Model 1216-26
0000224
Model 1216-42
0000807,
000102820-inch Drill Press
Type 1:
Type 2:
Bandsaws¶
Type 1:
19-639, 19-1049
1105842,
21-842, 1105-448
11356390,
22-639, 1135-448
Type 2:
BW740: 51BA4A
BN905: 51BC3AType 3:
3220: 0000571Type 4:
3200 Series: 32-0036Tablesaws
Type 1:
16-241,
16-544,
Type 2:
| “D” indicates TA1182 |
TC996/2100: 52AB2AType 3:
Type 1:
7-642,
7-645, 7-6248, RD642JL,
Type 3:
1612-2: 0000015Type 4:
- 16-0001 thru 16-0099
- 17-0001 thru 17-0099
- 16-0100 and higher
- 17-0100 and higher
Jig Saws (Scroll Saws)
Type 1:
MJ744, dates unknown: 7JS1239
J782, dates unknown: 7JS240
J915*, 1947 to 1959: 25-1147
Type 2:
51JA4AType 3:
4510: 0001000,
0001817Type 4:
Lathes
Type 1:
SVL52, 1944: 14-144
Type 2:
Type 3:
5110: 0000969,
2000719Type 4:
Sanders¶
Type 1:
Type 3:
5510: 0002914Type 4:
Jointers
Type 1:
P908, 1940: 8J240, 12J240*
Type 2:
Type 3:
6520-1: 0002092,
8000795Type 4:
Shapers
Type 1:
S1140, 1949 to 1953: 14-149
S1141, 1949 to 1953: 14-3249
Type 2:
Type 4:
Radial Arm Saws
Type 1:
23-243, RA343, RA642, 3-1949
Type 2:
Cut-Off Machines
Type 4:
