Page History: Yearly Maintenance Checklist
Page Revision: 2009/01/03 12:41
From owwm.com forum thread http://owwm.org/viewtopic.php?t=48970 by Bob VaughanYou can use this
downloadable version to use as a template for your own shop. Print it out and check off the items as you do them.
| | Kit (tool box top tray works well) |
_ | Oilcan |
_ | Grease |
_ | Cleaning rags |
_ | Allen wrenches |
_ | Cover removal tools (screwdrivers & wrenches) |
_ | Note pad and pencil (for noting big things & checking off items) |
_ | Small flashlight |
_ | Inspection mirror |
_ | Clipboard with this list attached |
| | Table saw |
_ | Blow out |
_ | Oil trunnions & gears |
_ | Tighten setscrews on handwheels |
_ | Check for loose pulley setscrews & belt wear |
_ | Inspect plug, cord, & starter |
| | Radial Arm Saw |
_ | Clean tracks & oil |
| | Bandsaw |
_ | Blow out |
_ | Check guides for wear |
_ | Oil upper wheel carriage |
| | Scroll saw |
_ | Blow out |
_ | Check oil level |
_ | Drop of oil in upper plunger |
| | Bench grinders |
_ | Blow out |
_ | Check wheels |
| | Lathe |
_ | Clean Morse taper sockets |
_ | Clean and oil tailstock clamp mechanism |
| | Jointer |
_ | Clean and oil working parts on fence |
_ | Inspect knives |
| | Planer |
_ | Check belts |
_ | Grease fittings, oil moving parts |
_ | Check knives |
| | Shaper |
_ | Clean and oil working parts. |
| | Drill press |
_ | Clean and oil working parts |
_ | Check chuck jaws |
| | Mortiser |
_ | Oil working parts |
| | Tenoner |
_ | Clean track |
| | Sander |
_ | Check oil level on OSS |
_ | Oil moving parts |
| | Compressor |
_ | Check oil |
_ | Drain tank |
| | Power Feeder |
_ | Inspect wheels, gears and chain |
| | Portable Power Tools |
_ | Gearbox oil (where needed) |
_ | Cords |
___ | Brushes |
