Page History: Yearly Maintenance Checklist
Page Revision: 2009/01/03 12:49
From owwm.com forum thread http://owwm.org/viewtopic.php?t=48970 by Bob Vaughan
You can use this downloadable version to use as a template for your own shop. Print it out and check off the items as you do them.
Kit (tool box top tray works well)
___
Oilcan
___
Grease
___
Cleaning rags
___
Allen wrenches
___
Cover removal tools (screwdrivers & wrenches)
___
Note pad and pencil (for noting big things & checking off items)
___
Small flashlight
___
Inspection mirror
___
Clipboard with this list attached
Table saw
___
Blow out
___
Oil trunnions & gears
___
Tighten setscrews on handwheels
___
Check for loose pulley setscrews & belt wear
___
Inspect plug, cord, & starter
Radial Arm Saw
___
Clean tracks & oil
___
Bandsaw
___
___
Blow out
___
Check guides for wear
___
Oil upper wheel carriage
___
Scroll saw
___
___
Blow out
___
Check oil level
___
Drop of oil in upper plunger
___
Bench grinders
___
Blow out
___
Check wheels
___
___
___
Clean Morse taper sockets
___
Clean and oil tailstock clamp mechanism
___
___
___
Clean and oil working parts on fence
___
Inspect knives
___
___
___
Check belts
___
Grease fittings, oil moving parts
___
Check knives
___
___
___
Clean and oil working parts.
___
Drill press
___
___
___
Check chuck jaws
___
Mortiser
___
___
Oil working parts
Tenoner
___
___
Clean track
___
Oil working parts
Sander
___
___
___
Check oil level on OSS
___
Oil moving parts
Compressor
___
___
Check oil
___
Drain tank
___
Power Feeder
___
Check oil level
___
Inspect wheels, gears and chain
___
___
Oil working parts
Portable Power Tools
___
Gearbox oil (where needed)
___
Cords
___
Brushes
